Clevo P750ZM (maybe bios problem)M.2 ssd and Wifi/lan not working
Discussion in 'Sager and Clevo' started by francisco santos, Jan 2, 2021.
  1. francisco santos
    francisco santos Notebook Enthusiast
    Sad day boys!
    The laptop is still not finding the m.2 drive and its really late ... I'm gonna get to sleep
    I Will be here tomorow trying again
  2. Tech Junky
    Tech Junky Notebook Consultant
    Ok..... photo shows a blank screen and two orange lights indicating power/charging in the off state.
  3. Tech Junky
    I know when I flash pc's they tend to mess with settings for M2.... just occurred to me with your BIOS photo. If the bios has Intel RST toggle it from off to on or on to off and see if that makes a difference otherwise it's electrically not showing up due to a fault on the board like stated originally.
    Possibly try defaulting the settings and/or short out the BIOS to factory defaults removing the battery within the case and holding the power button for 30 seconds to completely discharge the system.
  4. francisco santos
    I team good morning to you all
  5. francisco santos
    Im going to do that right now!
    Im gonna search also in the BIOS if the WiFi is turned off
  6. francisco santos
    Still nothing the m.2 is not present on BIOS
  7. francisco santos
    I dont know if I need to Change some values on BIOS or its doomed the laptop...
    Any help is always well received
    Im gonna post some BIOS pictures
  8. francisco santos
  9. Tech Junky
    The only thing that sticks out is the UEFI setting Windows 8+, this sometimes enables secure boot which can cause issues.
    Check under the "off board SATA" option and see if anything is hiding in there related to the M2 sockets. It's weird though to see so many SATA ports listed in a laptop. In the past I had a Dell M6600 that could squeeze 3-4 drives into the chassis between 2 x 2.5" / mSATA / and some other format.
    I think you mentioned a regular HDD worked it's just the M2 ports not working?
    They were working prior to starting the thread?
    Any changes to the OS / BIOS prior to the thread?
    Firmware updates?
  10. Meaker@Sager
    Well the m.2 slots can be SATA of course so they extend that list. I had the old p570wm which had 3x 2.5 inch slots which was amusing.
