Clevo P650HS-g nvidia 1070 dont work not showing in bios help!!!
Discussion in 'Sager and Clevo' started by Marcel123, Jul 9, 2019.
  1. Marcel123
    Marcel123 Newbie
    Hi got a P650HS-g with i7 7820hk and gtx1070 laptop only works when hybrid grafic in bios selected and gtx1070 is not visible in bios or windows if i select disctret gpu laptop start up not not pictures
    tried reset bios batery ect
    attaching bios pic can any owner of this model can post bios with similar photo
    in bios it says video card n/a
  2. jaybee83
    jaybee83 Biotech-Doc
    iirc that model only has switchable graphics and not a mux? if you want to use it in discrete mode u might have to use an external display via one of the ports.
  3. Meaker@Sager
    Is the dedicated GPU showing in device manager? If not it may have failed.
  4. Marcel123
    Marcel123 Newbie
    its not showing anywhere not in bios not in windows basicly gtx1070 is gone...
  5. Meaker@Sager
    Sounds like the chip is dead then.
  6. DaMafiaGamer
    DaMafiaGamer Notebook Deity
    On the plus side at least you get the data of the laptop and use it as it is. The GTX 1070 die is probably ok, it's one of those cheap ******ing mosfets on the side powering the gpu which has given up the ghost.
    ipodman715 likes this.
  7. Meaker@Sager
    That is something a decent repair shop could sort.
