Clevo P650HP6 webcam hardware issues
Discussion in 'Sager and Clevo' started by Legoboy0215, Oct 10, 2017.
  1. Legoboy0215
    Legoboy0215 Notebook Enthusiast
    Hello! I have been using my P650HP6 purchased from HIDevolution for about 5 months. However, recently I have been trying to use my webcam, which did not work for some reason (it previously did). I did some research and went on Device Manager, which showed this (I even had to turn on the show Hidden Devices option in View):
    Is this really a hardware problem, or is it a driver problem? If it is a driver problem, where would I get the proper drivers for my webcam?
    Thanks!
  2. gunemalli
    gunemalli Notebook Geek
    Check if you've disabled the Webcam from the Clevo Control Center application.
    Sent from my SM-G930F using Tapatalk
    Legoboy0215 likes this.
  3. Meaker@Sager
    Also check you have toggled the FN + F10 combo to on.
  4. Legoboy0215
    I feel dumb now. How did I not see that camera icon :p
    Thanks a lot!
  5. Meaker@Sager
    Like I say every time, you are not the first and wont be the last ;)
