Clevo P377SM (Sager NP9377) + Pascal GTX1060 = Possible?
Discussion in 'Sager and Clevo' started by temrus63, Aug 30, 2018.
  1. temrus63
    temrus63 Notebook Enthusiast
    good day friends!
    is it possible to upgrade this laptop (P377SM ) GPU for MXM3 GTX1060 6Gb.0b non G Sync?
    what is required for this?
    - eDP panel ?
    - Prema BIOS?
    - mod *.inf drivers files?
  2. Danishblunt
    Danishblunt Guest
    yes it is.
    You don't need Prema BIOS, you will need eDP panel and modded .inf drivers.
    temrus63 likes this.
  3. temrus63
    will the fan of the second (SLAVE) video card work without installing the video card (SLAVE)?
  4. Meaker@Sager
    The 10xx series cards have no "LVDS" output so yes eDP screen required.
  5. temrus63
    please tell me: if I have only ONE mxm graphics card in the P377SM - there will be worked THREE fan or only TWO?
  6. Meaker@Sager
    Two IIRC. Why? A 1060 is not stupidly power hungry compared to the old 980m cards.
  7. temrus63
    no, with one gtx980m - will worked BOTH gpu-fun? or only one fan will worked?
  8. Meaker@Sager
    You have the machine, it will work how it was specced at the time. If you have a fan leave it plugged in, if not don't go buying another.
  9. temrus63
    sorry for my English(
    I didn't put it right. I don't have a laptop yet.
    I'm going to buy it. I am worried about is if I have only one graphics card - gtx980m- are ALL the fans will worked?
    I'm going to combine heat pipe and all three of the radiator to effectively cool the 980m. It was believed that without the second graphics card will only run TWO fans, but not all THREE.
  10. Meaker@Sager
    I believe that is correct, only two will run.
