Clevo P370SM3 upgrade? Need help
Discussion in 'Sager and Clevo' started by Dendrit3, Sep 15, 2017.
  1. Dendrit3
    Dendrit3 Notebook Consultant
    Hello beautiful people!
    In 2013 I bought my first ever clevo Sager NP9380-S (CP370SM3), and boy it was a beastly machine! Now Im not sure wether I should go for a new clevo or upgrade the components. If I could get your guys expertise and suggestion I would appreciate it! So this how my setup is:
    17.3" 120Hz 3D
    4930MX Mobile extreme edition
    16GB DDR3 Ram @ 1600Mhz
    GTX780M 4GB SLI GDDR5
  2. Meaker@Sager
    What's your level of expertise with this sort of thing?
  3. Prostar Computer
    Even by today's technology, that's a fine system. What will you use the computer for 80% of the time?
    Dendrit3 likes this.
  4. sicily428
    sicily428 Donuts!! :)
    Is there an edp panel? Is there optimus?
  5. Meaker@Sager
    The 120hz is 50pin EDP IIRC. SLI supporting machine so no optimus.
  6. sicily428
    so msi Gtx1060 should be compatible!
    or new eurocom gtx1070/1080
  7. Dendrit3
    Sorry for the delayed reply and thank you for your inputs, much appreciated.. means alot! :vbthumbsup:
    I would say my level of expertise is pretty solid, what can I do to make this beast alive again? I might get someone else to do it if its too complicated. So lets hear it. :)
    For gaming I would say. With current build I can't max out today's games. High settings pretty much. What's your thoughts?
    Will I really be able to run the latest gpu 1080 on this? that would be awesome! :)
  8. Prostar Computer
    If you're going for max settings on current and future titles, that's a tall order. The right mods might help you get some better video cards in there. Your CPU should handle most anything current just fine; I don't see a bottleneck there, at least.
  9. Meaker@Sager
    People have been experimenting with 1060s and that ilk. A 980M would certainly be doable.
  10. Dendrit3
    Yeah CPU is still really good as you said, no need to upgrade it. But just out of curiosity is the 4960X the highest CPU I could run? Not a significant difference there.
    980M seems to be the right choice as of now. But the question is run 980M SLI or a 1060? Not sure about that.
