Clevo P370sm-a fan and graphics card problem
Discussion in 'Sager and Clevo' started by KuroSan, Feb 22, 2018.
  1. KuroSan
    KuroSan Notebook Enthusiast
    sorry, i meant I²C interface.
  2. Meaker@Sager
    The EC monitors a variety of signals from different components, it's indeed not just a simple single sensor.
  3. Kostasgreece
    Kostasgreece Notebook Enthusiast
    you measured the graphics card? it is shorted anywhere? I have a 980m shorted on voltage regulator and 1 mosfet burned. I would try to fix it. what did you see between coils and ground?
  4. KuroSan
    from inductors (Coils) to ground is 0.1 ohm. what is the voltage regulator for you? with my card's behavior i suspected the up1642 ic to be malfunctioning.
    take a look at this:
  5. Kostasgreece
    yes the regulator is the same. when I removed it the shorted circuit go away. I measure and two mosfets csd87350 one of them is shorted. now I be waiting from China for new mosfet and voltage regulator. I measure now coils and ground and it is 0.8 at beeper. your card's voltage line is shorted? it is the first line on the right
  6. Meaker@Sager
    Depending on where you are places like Digikey are great for getting chips.
  7. KuroSan
    @Kostasgreece
    what is your cards behavior? 22 beeps, black screen, sometimes working, code 43 in device manager?
    be careful when you measure the 87350 - result is only reliable when they are completely discharged. it's more easy to measure the pci express connector for a short.
    the large contact in the right(top view) are 7-20V input rail and should read about 6Kohm - check polarity before. if it's a lot less there could be a short in mosfets. if you have already removed them simply put your finger on the contacts for a second - your bodys resistance will discharge them quickly - then measuring will be more reliable.
    @Meaker@Sager
    yes, those places are great,but very expensive. i tried to buy these mosfets here in germany, but most shops don't sell them - only mouser but they wanted around 20€ delivery for 5 pieces which is
    ridiculous.
    the chinese parts are working good, and are cheap with a price of 2$ a piece with no extra delivery cost you can't go wrong if you have the time to wait.
  8. Meaker@Sager
    You just have to be careful regarding genuine parts.
  9. Kostasgreece
    no my card stop working and for 3 seconds stop in the same picture,after that all the system close and when the card is on the laptop was shorted and do not opening the system. I found the first line from the right shorted. when i desolder the up1642p and the other mosfet is not shorted anymore the line. i hope my card was ok after that.
  10. Kostasgreece
    i found the parts from China (aliexp) . in my country Greece is very difficult to found everything like that.
