Clevo P370EM MSI 980 HELP
Discussion in 'Sager and Clevo' started by Damin, Jan 21, 2020.
  1. Damin
    Damin Notebook Consultant
    Hello all so I get the drivers installed and SLI working but no internal display on the 17.3 screen .
    Only display on HDMI out
    This was not a issue on my single GPU P150SM
    Can any one shed some light
  2. Khenglish
    Khenglish Notebook Deity
    You're using an LVDS display, or do you have an EM3 system with an eDP screen?
    Also can you get the internal display to work after you boot into windows?
  3. Damin
    I have both a P370EM and a EM3 and SM systems . Once in Windows only display on the HDMI out
    I'm assuming the p370em3 is the one with the 120hz display I think I updated that one with the eurocom bios ( the p370em bios )..maybe I should flash it back
    Some pics
  4. Meaker@Sager
    The 980m should also support LVDS still, it's going to be either bios or vbios that needs changing.
  5. Damin
    This is not the usual 100W 980m it's the MSI 130-140w iirc they do use the EDP on the GT80 6QF ... but I think my p370em 3D uses the same . Might be the actual BIOS being the Scorpion X bios
  6. Damin
