Clevo P177SM-A Overheating - Thermal pad help?
Discussion in 'Sager and Clevo' started by WhzBlo0, Feb 10, 2019.
  1. WhzBlo0
    WhzBlo0 Notebook Enthusiast
    Hey guys! could use a bit of help. My laptops GPU has been overheating quite a bit ( reaching up to 93c when running something GPU intensive) and was wondering if you could lend me some advice? I tried repasting my GPU and CPU using Thermal Grizzly Kryonaut, and my GPU is still over heating (reaching 94c now!). Followed the instructions on the package using a thin layer of thermal compound. I'm assuming the issue might have to do with the thermal pads. and my GPU memory overheating...in which case, does anyone have a guide so i know what thicknesses to use and where to place them?
    I also purchased new fans just in case, but barring that is there anything else i can do to increase airflow and decrease my thermals? Is thermal grizzly conductonaut compatible with the heatsinks for this machine?
    Also what sort of applications should i be running to get average temps? What should my GPU temps be ? Thanks for any help in advance !
    I have a GTX 880m
    i7-4910MQ CPU @ 2.97ghz
    running windows 8.1 pro
    Clevo P177SM-A Chassis aka SAGER NP8298 (Via Mythlogic)
  2. jclausius
    jclausius Notebook Virtuoso
    <pls delete>
  3. Meaker@Sager
    Dont pre spread, you introduce aur bubbles. Use the pressure of the heatsink on a pea sized blob to spread it.
  4. WhzBlo0
    Thanks, I'll try that out next time I repaste. Off hand you wouldn't happen to know what sort of thicknesses and where i should place new thermal pads at ? Could i use a liquid metal paste without damaging my heat sink ?
  5. Meaker@Sager
    It sounds like you are new to this so perhaps best to avoid liquid metal. Not off the top of my head on thickness but you can measure the original pads to get an idea to the nearest 0.5mm.
  6. WhzBlo0
    Thank you for the suggestion, and prompt response. I have over a decade of experience using standard thermal compounds while building and servicing fleets of desktops. Wasn't able to find a definitive answer for whether or not the heat sink would be damaged using liquid metal compounds during my research. Heating pads are new to me as most components in desktops typically don't need them unless you're doing extreme overclocking. I've seen some diagrams for other clevo models, and they seem to have a variety of different thicknesses in various locations. I was able to determine the thicknesses of a few, but given the fact mythlogic was kinda slipping the last time i sent my machine in for repair I suspect they may not have placed enough / used the right thermal pads, as a few seem to be missing judging by other models. it looks like 1.5 might fit for some of them, and I was going to purchase Fujipoly thermal pads, just wanted to make sure i get it right, since that brand is quite expensive.
  7. Meaker@Sager
    Liquid metal can be used on copper heatsinks, it must not touch aluminium. To use it there must be pretty much perfect and close contact to the die.
    Thermal pads need to be touching:
    VRM chips (the very little little black squares)
    and
    Memory chips (the big black squares around the core)
  8. Prostar Computer
  9. Meaker@Sager
    It can feel fun to crush aluminium with your bare hands.
  10. WhzBlo0
    Yea I knew that, i just wasn't;'t sure if the heat sink or the GPU die was made of aluminum or was a copper plated aluminum alloy. Is there a way to test it ? Anyone know off hand?
    As far as thermal pads go, should i just go for 1.5 all around? would that be enough for the gtx 880m? If i go too thick would that cause issues ?
    edit: w/pics
    https://imgur.com/a/tDcz9vr
