Clevo P150EM with fried network/LAN port
Discussion in 'Sager and Clevo' started by aggie113, May 1, 2021.
  1. aggie113
    aggie113 Notebook Guru
    So, thanks to a lightning strike and poor planning on my part I now have a non-functional lan port on my Clevo P150EM. I have ordered a USB adapter but would like to see about replacing the part(s) needed to get a working LAN port again. I don't have a SMD/PCB repair station, so swapping parts will have to do.
    Could I replace this with a P151EM board? Would that allow transfer over of ram/cpu/gpu?
  2. Tech Junky
    Tech Junky Notebook Deity
    I upgraded my setups with 5GE for hardline access and picked up a USB-C 5GE adapter for ~$60
    For your average USB/ETH adapter though they're in the $10 range for a gigabit.
    I guess the bigger question is..... Why wired when you can do GIG over wifi these days?
  3. aggie113
    Wired is always better when available. And since my desk is 10ft from my networking equipment it wins. Wireless is only used when it's the only option for a device or the device must be used in no fixed location.
    So now that we have a knowledge of my philosophy on the subject, can I get an answer to my inquiry?
  4. Tech Junky
  5. aggie113
    Well if you want to send a board over to try, I'll rely on Maybe's baby.
    :p
  6. Tech Junky
    Can't help you there with the board but, they're in the same series and there are subtle differences between them. There will likely be some trade offs between models.
    The problem with these is that once they're not being sold nay longer it's hard to compare them side by side. Once they're ~ 1 year out of production the stats on them disappear.
    Looking here https://repo.palkeo.com/clevo-mirror/P1xxEM/ (repo/repo) they fall under the same service manual Filip through the manual and see if you spot some differences between the 2.
