CLEVO p150 SM-A/ Sager NP8268 not posting.
Discussion in 'Sager and Clevo' started by krisrgarrido, Apr 18, 2020.
  1. krisrgarrido
    krisrgarrido Notebook Enthusiast
    Hello I have an old CLEVO p150sm-a (SAGER NP8268) with a gtx 870m and a 4th gen i7. It was heavily used before in my college days but recently its just laying here in my storage. The last time I opened it was 2months ago and I decided to open it again but It didnt post at first, I left it open and it booted into windows after atleast an hour of it being plugged. But when I restarted it, it did not post anymore even if I waited for an hour. I already tried removing the ram, changing power supplies, using an external monitor but nothing seems to work. All i get was a black screen with capslock and numlock not even turning on and the power indicator led light. I noticed that when its on for 5 mns the fan of the cpu turns on, and I also tried removing the MXM and when I did the capslock, numlock, scroll lock kept on blinking and the cpu fan went to 100%. I was suspecting at first that it was a motherboard problem but now I think its a gpu problem? I would gladly want to hear your thoughts on this, is it still recoverable?
  2. Meaker@Sager
    Are both the CPU and GPU VRMs getting hot?
  3. krisrgarrido
    The last time I checked, they were.
    Edit: I failed to mention that the power button is not working anymore, so the way I turn it on is that I remove the battery and then plug in the AC. (I dont know if this info is at any help.)
  4. Meaker@Sager
    Does it respond if you remove the GPU?
  5. krisrgarrido
    As I said, yes it does, the capslock numlock and scrl lock kept blinking and the fan goes to 100% when i remove the GPU. fn+1 also makes fan speed up.
  6. Meaker@Sager
    Sounds like there is a short on the GPU then.
  7. krisrgarrido
    I know this is an old post, but is it possible to boot the laptop without having an mxm gpu? I really just want to use it as spare productivity laptop. If not, what's the cheapest mxm gpu you can get to get this laptop running again?
  8. Meaker@Sager
    It will go into a EC panic and shut down after 30 seconds with no GPU.
    Cheapest depends on the market at the time in your part of the world.
  9. BrightSmith
    BrightSmith Notebook Evangelist
    You could try to bake the gpu as a last resort
  10. Meaker@Sager
    Usually the smaller quadros of a similar generation are a safe bet.
