Clevo M860TU fan replacement
Discussion in 'Hardware Components and Aftermarket Upgrades' started by demonshin, Jun 25, 2010.
  1. demonshin
    demonshin Newbie
    So I my fan in the laptop is dying...sounds like the ball bearing or something is giving as it makes noise while spinning.
    Do you guys know a solution to fix or a replacement fan I can use? I tried to look for replacements but did not find anything and try to find something on the forums as well, any info will help. Thanks
  2. Marecki_clf
    Marecki_clf Homo laptopicus
    Try WD40 :)
  3. lappyftw
    lappyftw Notebook Guru
    Try to contact with Clevo for a replacement,or simply lubricate the ball bearing.It should work.Wd40 is not proper for this as it does not adhere to metals/plastic and not dense that it will directly got off and spill/spread to all over the place if the ball bearing rotates.
  4. sysserv
    sysserv Newbie
  5. sean473
    sean473 Notebook Prophet
    get them from ebay.. it will be fast and quick.
  6. HTWingNut
    HTWingNut Potato
    Please show me where you can buy Clevo parts on eBay besides a keyboard...
