Clevo Fan Control
Discussion in 'Sager and Clevo' started by Danishblunt, Mar 9, 2018.
  1. KuroSan
    KuroSan Notebook Enthusiast
    it's version 5.0001.0.39 - just wrong file name in this list..
    Danishblunt likes this.
  2. Danishblunt
    Danishblunt Notebook Prophet
    I'll be damned. Now this is amazing. I'm on youtube and the fans are not spinning. Thank god. Under stresstest the fan profile is pretty good!
    Thank you man this control center version will get on my "treasure USB stick" alongside the Prema BIOS and Phoenix software kit =D
    @XMG
    Thank you for having decent control center.
    XMG and KY_BULLET like this.
  3. KuroSan
    Glad i could help you. my 980m had to die because of the control center version xmg is having for download for my P724 - gpu fan profile not working properly.
    my new card was overheating too with this version it reaches 70 degrees maximum.
  4. hexum23
    hexum23 Notebook Evangelist
    Will this work on a P870DM3? I’m getting tired of loud fans when just surfing the web. I’m on Prema bios from fall of last year. I’ll get in touch with HIDEvolution today to get latest bios and maybe that will help. But otherwise I’d like to try this version of hotkey if it helps with the fan noise.
  5. Danishblunt
    It should work. I think in your case it's more a temp problem than a fan problem. Only thing that is out of control is the damn GPU fan.
    hexum23 likes this.
  6. 3uphrates
    3uphrates Newbie
    Well thank you. I was mad with the fan behavior of my Clevo W550SU, installing 5.0001.0.39 Control Center made significant improvement
    I do have XTU installed for a light undervolt.
    Also I edited CC OEM.ini file with SupportXTUFanTable=0 parameter.
  7. XMG
    XMG Company Representative
    To clarify, actually the P671RG is the XMG P706 - the XMG U706 is based on the P771DM1 chassis.
  8. Jmanthesin
    Jmanthesin Notebook Enthusiast
    Will this work on the pa71hs?
  9. Danishblunt
    Probably since clevo is a lazy company and reuse the same software over and over again for different models I wouldn't be suprised if it would work.
  10. Meaker@Sager
    Why would you re-write the software for every model? That would be nuts.
    oSChakal, jclausius and aIex like this.
