Clevo Fan Control
Discussion in 'Sager and Clevo' started by Danishblunt, Mar 9, 2018.
  1. Danishblunt
    Danishblunt Notebook Prophet
    Is there any way to control my fan on a better way on my P375SM-A? So far as soon as the temps reach around 60c the CPU fan ramps up by 80% for a couple of seconds and then ramps down to around 10% after it cooled the CPU down to 50c. This is not only annoyingly loud but completely stupid considering that the notebook would be absolutely fine on ~20%.
    When looking at Clevo control center the "fan control" seems to work the same way, it's completely unusable.
    bennyg likes this.
  2. Prostar Computer
    Even in the final updates, the fan profile behaved similarly. What version EC do you have?
  3. Danishblunt
    Got premamod on it. so EC + BIOS is the most recent with premamod.
  4. Prostar Computer
    Probably best to confer with Prema, then. I'm not sure if any adjustments to fan tables were made in his mod for this specific model or not.
  5. Danishblunt
    Pretty sure it isn't the model allows for custom fan profiles, so I'm actually looking for software or so that can fix this instead. It doesn't seem like I'm bound to internal EC fan profiles.
  6. KuroSan
    KuroSan Notebook Enthusiast
    Hey Danishblunt,
    try using Clevo Hotkey app for P671RG(aka XMG U706). even the user defined setting is working for my P377sm-a.
    their version is 5.0001.39.
    I'm totally satisfied with this version.
  7. Danishblunt
    Canyou give me a direct link?
  8. KuroSan
  9. Danishblunt
  10. KuroSan
