Clevo Fan Control for Linux
Discussion in 'Sager and Clevo' started by Dennismungai, Oct 31, 2018.
  1. Dennismungai
    Dennismungai Notebook Deity
    Hello there,
    Tuxedo Computers has released tuxedo-fan-control, a program that introduces fan control on Linux-based systems for Clevo barebones.
    Project: https://github.com/tuxedocomputers/tuxedo-fan-control
    Relatively straight-forward to build and deploy on many Linux variants, from Debian based systems all the way to the SUSE family.
    For back-light control, take a look at this: https://github.com/tuxedocomputers/tuxedo-keyboard
    I'll test this on the P751DM2-G later on in the day and report back with results.
    Limitations and usage:
    See the user guide: https://github.com/tuxedocomputers/tuxedo-fan-control/blob/master/docs/user/user_manual.md
    Dev manual, see: https://github.com/tuxedocomputers/tuxedo-fan-control/blob/master/docs/dev/dev_manual.md
    The notes in the second document point out the first known limitation concerning dual-fan GPUs found on some models, such as the P955ER: Only one GPU fan in such a setup can be controlled.
    On future goals for the projects:
    Tuxedo intends to upstream this work , separating the older WMI driver into multiple submodules and clean-up work needed to merge this to the Linux kernel. We can expect multiple WMI drivers for Clevo based barebones that can be configured in the kernel in the future.
    FYI: The fastest way to track changes in the Linux kernel without subscribing to the LKML is through the kernel newbies changelog. It has a good summary of what to expect in the current stable kernel.
    hmscott, prohobo, rommer and 7 others like this.
  2. rommer
    rommer Notebook Enthusiast
    Excellent news! Thanks for sharing!
    I plan on dual booting Linux and Windows.
  3. Dennismungai
    You're welcome.
    My hands have been pretty tied up this week (embedded systems dev work is time consuming), haven't had the time to test the fan controls on Linux (yet).
    What system are you on at the present?
  4. rommer
    I run Ubuntu 18.04 on my current HP laptop. All of my servers are Linux based as well.
    I have approximately 3 dozen different VM's that I run on my laptop based on the work I need to do at the time. (No, I don't run them all at the same time!)
  5. rommer
    @Dennismungai,
    Finally got around to checking out your software. The keyboard software works great!
    Having issues trying to build the fan control and I was wondering if the referenced deb file was available for download and if there is a cost involved? I'm running Ubuntu 18.04. There appear to be some missing script files and the build fails.
    Thanks
    John
  6. Dennismungai
    Thanks, but I have no involvement whatsoever with the software, or with Tuxedo, as a company.
    Have you installed the requested dependencies, namely nodejs,
    autoconf, automake and build-essential packages?
    They can be installed via:
    apt install autoconf automake build-essential nodejs
    No. However, the build system generates these artifacts, via cpack.
    Also, no. It's completely free.
    Let me verify the build instructions. Perhaps they've omitted some dependencies in the process. If this is the case, I'll submit a pull request with updated documentation on the same.
  7. Dennismungai
  8. rommer
    I was able to work on this today and it worked great with one minor issue.
    The final instruction fails with no file found and needs to be changed:
    Original: sudo apt install output/build/*.deb
    Fix: sudo dpkg -i output/build/*.deb
    After that, it's working great.
  9. Dennismungai
    Thanks for noticing the issue, creating a pull request to update the documentation.
    Update: Done.
  10. prohobo
    prohobo Newbie
    Thank you (and Tuxedo) for this you disgustingly beautiful m*********! I have an old Clevo (2014) and it only has a CPU fan that up until now has been running at 100% whenever I breathed near my laptop. My room sounded like the inside of a cargo plane on Skype calls, and I could never access the BIOS fan controls for lack of new drivers. Now, I modified the daemon code a bit and the CPU fan speed follows the table whether it's my CPU or GPU starting to heat up. Much, much.. much quieter. I was considering ending it all, but this saved my life.
    Whoever it was at Clevo or XMG/Schenker that set the fan speeds on my laptop deserves to live in a server farm.
    Dennismungai likes this.
