Cleanup ISO with MSMG, then maintaine with NTLITE?
Discussion in 'Windows OS and Software' started by arenaboy007, Mar 18, 2018.
  1. arenaboy007
    arenaboy007 Notebook Geek
    So I just thought of this idea of cleaning up an ISO with MSMG toolkit and then saving the removals as a preset in NTLITE so I only need to run it every after a cumulative update. What do you guys think?
    The reason for this is to keep the removals reasonable, which I think the toolkit does well, but then it doesn't have the live feature that NTLITE offers. Basically, getting the best from both worlds.
    Vasudev likes this.
  2. StormJumper
    StormJumper Notebook Virtuoso
    I used the MS ISO 1709 and had no junk installed.
  3. Ultra Male
    Ultra Male Super Tweaker
    Really? What does this have to do with his question? :rolleyes: Can you like for once, just post ANY useful answer? :rolleyes:
  4. Vasudev
    How is that possible? Last time I checked FCU had too many unused UWP apps which acts like a banner or ad.
    Ultra Male likes this.
  5. Ultra Male
    Just ignore anything that guy says, he always posts such comments which make 0 sense, incorrect, misleading, etc. then he runs away to the next thread....
  6. slimmolG
    slimmolG Notebook Consultant
    lol
    One person's junk is another person's treasure... But let's not talk about people's junk.....
    If 1709 wasn't littered with the same ol' low-quality, low-power, good-for-everyone "productivity"/advertisement/info-tainment software as the previous versions, I'm pretty sure the secret would be out by now.
  7. slimmolG
    Oh, forgot the actual intent of my response, if anyone's reading this:
    What about OP's original question? I haven't used NTLITE, but I'm interested in checking it out:
    Vasudev likes this.
  8. Vasudev
    You can do that.
    slimmolG likes this.
  9. Ultra Male
    I don't use it, I have the paid version, even the last version, it just breaks Windows, random bugs like in the PC Settings some tabs are just chopped off, sticky notes randomly stops working, etc. that's all I can remember for now but it is one buggy mess. The MSMG Toolkit also breaks Windows Updates from functioning so that goes out the window as well.
  10. Vasudev
    Sticky notes and others aren't there on RS4. Blindly removing everything will break. Use the default profile to keep what is needed in components page.
