Cleaning Products
Discussion in '2015+ Alienware 13 / 15 / 17' started by StanJarensky, May 19, 2017.
  1. StanJarensky
    StanJarensky Notebook Enthusiast
    Hey guys, I have a 15R3 and I love that the body doesn't collect too much fingerprints but I do notice it getting dirty. What are the best cleaning products for the body, keyboard, trackpad, screen, etc? Do most of you just use water and compressed air? Any tips or tricks?
  2. Vasudev
    Vasudev Notebook Prophet
    Use microfiber cloth to clean it.
  3. SkidrowSKT
    SkidrowSKT Notebook Deity
    Microfiber cloth [and some alcohol: DO NOT USE IT FOR RUBBERIZED PALM REST CLEANING] for external cleaning, compressed air for internals. Keyboard can be tricky when food or small objects are stuck in between keys, so you might want to use cotton swabs.
    Sent from my SM-N900 using Tapatalk
    Vasudev likes this.
  4. liviu2007
    liviu2007 Notebook Enthusiast
    I have bought a complete skin and covered mine.found on ebay red carbon skin.specialy for the front where your hands sit.protection from scratches and smudges. ^^
  5. rinneh
    rinneh Notebook Virtuoso
    DONT USE ALCOHOL!!!!!!!
    it will eat through the soft touch finish in time. Never use alcohol for rubberized surfaces!
  6. SkidrowSKT
    Is the finish in the AW15 rubberized? I've been using it for years in my Acer laptop, no issues. But the finish in mine isn't rubberized.
  7. rinneh
    The palmrest is rubberized. it is mixed with another coating so it will take some more time. but eventually it will create airbubbles under it and after you can wipe the coating straight off.
    SimplyJ3sse and SkidrowSKT like this.
  8. SkidrowSKT
    I've added a warning just in case.
  9. judal57
    judal57 Notebook Deity
  10. alexnvidia
    alexnvidia Notebook Deity
    just damp cloth will do the job fine. warm damp cloth will be more effective
    SimplyJ3sse likes this.
