Choosing the right GTX 980M for 8770w?
Discussion in 'HP Business Class Notebooks' started by TenGauge, Sep 8, 2017.
  1. TenGauge
    TenGauge Notebook Guru
    This is a screenshot from right after I installed the DC panel. 2017-11-30_19-49-52.png
  2. mirage_bg
    mirage_bg Notebook Evangelist
    I was also able to make the card working on Win 10 Uefi with 388.13 driver (actually windows installed them automatically on first boot)
    The problem appears when I try to update the driver with newer/older one- after restart - black screen.
    When put the laptop on sleep - black screen on wake...
    Brightness stays on max and hot keys doesn‘t control it..
    Cold boot = black screen, have to force reboot with power key, then works...
    What remains in mind is that my problem is the combo 8760w DC+ GTX 980m.
    You are using 8770w and if you haven‘t faced those problems, there is clearly better compatibility of 980m with 8770w DC.
    No other explanation...
  3. mirage_bg
    I think I am just out of luck ... in a Polish forum I saw a guy with same combo as mine (8760w DC+ 980m) and he has experienced exactly the same problem as me, unresolved by now for already six months...
    I am going to sell this card.
    Will keep using my 780m, clocked at the speed of 880m.
  4. mirage_bg
    Did you find any solution about those blank screens? I am in the same boat...
  5. Danyel254
    Danyel254 Notebook Enthusiast
    Brightness control works? Fan control works? Hdmi audio and video works?
  6. mirage_bg
    I am also interested if brightness controls work on your setup?
    Does your DP port work too?
  7. mbze430
    mbze430 Notebook Enthusiast
    I have an 8770w 1080p NON-DC panel. Also looking to replace the stock K3000M with a Maxwell GPU.
    But what I haven't been able to find in this thread is the 980m MXM 3.0 cards do they ALL fit or only a certain type (A or B)? or there are no "standards" in card dimensions?
  8. mirage_bg
    3.0b is what you need.
