Checking hard disk for consistency?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by londez, Nov 23, 2009.
  1. londez
    londez Notebook Evangelist
    Today when I turned my laptop on, it went into a screen before it booted windows said that it had to check the hard disk drive for consistency, but then it just got stuck there. I rebooted it and it just went right into windows. Last time I got this message on my Asus I had to replace the HDD.
    Is this message an immediate death sentence for the hdd?
  2. tilleroftheearth
    Do you move your computer when it's on? Do you bang it or otherwise make the HD take impacts while it is running?
    I use my notebook a lot, but I always wait until the HD light is out before I move it or put it back into it's case.
    When it's checking the drive for consistency - it shouldn't get 'stuck', it may seem like that to you but give it time - as long as the HD light is still on - it is trying to correct whatever errors it detected.
    My suggestion? Go into My computer, right click on all the drives (one at a time) go to Properties, Tools, Error Checking, Check Now, check both boxes and reboot your computer.
    Now, go watch a movie - this could take a while. :D
    Hopefully when this finishes properly, Windows will have marked any bad clusters as 'do not use' internally and assuming you'll be more gentle with your notebook, you won't have a problem.
    Good luck!
  3. londez
    I'll try that, thanks! I'm very good to my laptops. Heck, I buckle it's case up whenever I have to drive somewhere with it.
  4. tilleroftheearth
    LOL, Yeah, I buckle her up too (yup, my VAIO is a 'she')!
  5. surfasb
    surfasb Titles Shmm-itles
    I wouldn't worry too much about it.
  6. londez
    Okay, I did what you told me, but it's hanging at the disk check abort screen, and the HDD light isn't flashing either.
  7. londez
    OH CRAP!!!!!! I can't restart without the disk check starting up and It won't let me abort either!!! Please help!!!
  8. SoundOf1HandClapping
    SoundOf1HandClapping Was once a Forge
    Huh. Same problem.
    And if Londez's problem is like mine, it is stuck at consistency check screen. I booted up my computer and it told me my seconad HDD--there's only games on this one, mind you--needed to be checked. So I left to run some errands and came back an hour and a half later... and the screen was still stuck at "1" on the countdown. Oh, and no matter how many buttons I hit the check won't abort.
    Managed to find a workaround, and both HD Tune and the built-in Windows Check Disk report zero errors. My HDD also click-whirs.
    Londez, try booting in from safemode and then restarting into normal mode. And are you running Win7?
  9. londez
    yeah, I'm running windows 7. GRRRRRR!!!!!
  10. londez
    Crap Crap Crap!!!!!!!!! It Won't Even Start In Safe Mode!!!!!!!!! What The Heck Is This Crap!!!!!!!!!!
