check whos using my wifi and disconnect them?
Discussion in 'Windows OS and Software' started by times, Feb 6, 2009.
  1. times
    times Notebook Evangelist
    what software would i use to see if there are any outside connections coming into my wifi and would it be possible to click on that connection and dissconnect them?
  2. vi3tscorpian
    vi3tscorpian Notebook Evangelist
    why don't you secure it using passcode?
  3. whizzo
    whizzo Notebook Prophet
    what he said. simple to set up, and reasonably hard to circumvent/defeat.
  4. malai5
    malai5 Notebook Enthusiast
    If you go into your router's control panel on line, you will be able (hopefully) to see the computers that are accessing your router.
    You should also be able to block their IP address.
    Have a wander round in the control panel of your router and see what it can do for you.
    Cheers
    Malai5
  5. PhoenixFx
    PhoenixFx Notebook Virtuoso
    As already said, best way to keep out others is by securing your network with a password, or use MAC address filtering (which will restrict computers by hardware : network adapter to be specific)
  6. Alex
    Alex Super Moderator
    As Malai5 says
    Access your router
    Look to see the computers that are or have logged in
    You can deny use by mac address
    Alex
  7. paperkut
    paperkut Notebook Consultant
    MAC filtering is useless. Use a WPA2 key with a 10 character long alphanumeric password.
  8. Alex
    Paperkut
    There is lots of ways to make it more secure,if thats important
    Going off topic a bit:
    I have made mine an open access wi-fi link
    We in Canada have been fortunate enough to be ahead of the usa with high-speed broadband saturation
    I do have the bandwidth to share
    My views are a quite different than most here as far as sharing and security as well
    In most large citys we can log-on without paying for hotspot access which is the trend that some large us corporations like starbucks etc are trying to get away with
    They are not that popular here as we do have the bandwidth
    Alex
  9. paperkut
    Tomcat that's great. I hope the US is also able to reach that kind of broadband availability in the future. But getting back on topic, the average consumer here will most likely NOT want his bandwidth leaking out. And currently, no method of security besides WPA2 encryption will be sufficient. The rest is just a gimmick and people should stop using them as it just perpetuates the illusion of security.
  10. times
    okay guys.thanks for the suggestions.will do
