Charging a thinkpad x240 or a T440 with a power bank?
Discussion in 'Lenovo' started by Sid Shah, Sep 29, 2019.
  1. Sid Shah
    Sid Shah Notebook Enthusiast
    Hi, so, I am buying a iMuto 30000mAh Portable Charger X6 power bank.
    Link: https://www.amazon.com/30000mAh-Portable-X6-External-Nintendo/dp/B01LYVF137
    Can I charge the Thinkpad x240 or a Thinkpad T440 with this by using a UCB-c to Slim tip converter? Its DC power, 5v/2A charging output from the power bank. I wasn't able to find the charging current for either of the machines so I am asking here if it's possible.
  2. saturnotaku
    In all likelihood that's not going to work. You would need something like this instead.
  3. Sid Shah
    Okay, but I am curious as to why won't it work?
    Do the laptops that I wrote about need a higher wattage output?
    Is the 5v2a current not enough to properly charge these two devices?
    Also, can an X1 Carbon (earlier gens that have slim tip chargers) be charged by this? Or do I have to get a later gen X1 model (those have C-type chargers) to be able to use my battery bank to charge my laptop?
  4. saturnotaku
    USB-A is not designed to handle the sort of power delivery that charging a laptop battery requires. USB-C can do up to 30W. The pack I linked to above can do this or up to 85W over its standard 3-prong AC plug.
    Sid Shah likes this.
  5. Sid Shah
    Yes, alright, I saw that product and I get your point.
    However, I am curious as to how much wattage do these Thinkpads normally require?
    Will a 63W power bank by AUKEY be enough?
    https://www.aukey.life/products/pb-...ry-3-0-usb-c-power-bank-with-quick-charge-3-0
    My friend bought this from a local vendor and gave it a good rating.
    They claim "USB-C with Power Delivery: Fully charge the power bank with your MacBook 2016/2017 and charge your MacBook Pro 13inch with 45W of Power."
    That seems to be more than enough wattage from a USB-C port, don't you think?
  6. custom90gt
    Usb-c can provide up to 100W of power to a device (or more if they've exceeded the spec like the XPS 9575). I believe my X240 came with a 45w power adapter so I would think 63W would be more than enough. I can't comment on the usb-c to slim-tip converter however. Usb-c does negotiate how much power to supply, my worry is your tip may not be able to "convey" that to the adapter and allow it to step up to higher voltages/amperage.
    saturnotaku likes this.
