Charger not detected, but battery is. Can I connect a charger to the battery connector?
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by tglaria, Mar 2, 2012.
  1. tglaria
    tglaria Notebook Enthusiast
    So I have a Dell M1330 that doesn't detect the charger (so can't charge the battery and can't run plugged directly to the charger), but it works without any problem when working from the battery.
    So, I was wondering if I could connect the/a charger directly to the battery to charge it and use it OR get ride of the battery and connect the/a charger directly to the battery port. I would need a 11.1V power supply I guess (that's the battery voltage).
    Any ideas if this is even possible?
    I haven't been able to find any information, at most the battery pinout/pinin, but that's about it.
  2. ThinkLover
    ThinkLover Notebook Consultant
    I think that fixing power connector is a way better solution...
  3. Nick
    Nick Professor Carnista
    Your power adapter might be defective. You can find a new one on eBay for $15. Make sure you get an OEM Dell adapter, and not a cheap Chinese fake.
  4. tglaria
    The power connector works (at least I get voltage from under the motherboard).
  5. tglaria
    Tried with 3 different power adapterts which work on other machines. So no, it's not the carger.
  6. Nick
    Ok, you can find a new jack on eBay for under $5.
  7. tglaria
    If I can check the voltages from under the motherboard, shouldn't this mean that the power jack works ?
  8. Nick
    It might not need a new jack. However, the Dell 1525 had a jack problem where it wouldn't recognize the adapter nor would it charge the battery. But, it will still power on and run of the adapter. To fix it, you had to replace the power jack.
