CHARGER COMPATIBLY CF-28
Discussion in 'Panasonic' started by Wyoming88!, May 16, 2019.
  1. Wyoming88!
    Wyoming88! Notebook Evangelist
  2. UNCNDL1
    UNCNDL1 Notebook Deity
  3. kode-niner
    kode-niner Notebook Consultant
    Haha, "Genuine original".
  4. UNCNDL1
    Look for one of these as well:
    Sent from my CF-M34
    Shawn likes this.
  5. UNCNDL1
    I know...funny but the connector is what’s important...
    Sent from my CF-M34
  6. Shawn
    CF 28 and CF M34 take this connector
    The one you linked has this connector.
    Voltage and amps are fine though.
    toughasnails and UNCNDL1 like this.
  7. Wyoming88!
    So could I switch the heads or whatever there called from the IBM adapter?
  8. Shawn
    I swap the cords from one "head" to another all the time, but I have the skills and the tools to disassemble, unsolder-resolder and re-assemble.
    I don't recommend that to anyone without the knowledge or tools.
    The part number recommended above by Cleve is a good choice that will work with no modifications needed.
    sony pcga-ac16v6
    UNCNDL1 likes this.
  9. Wyoming88!
    Ok. My last resort then is to idk put a thinkpad charger port on it or something. (Not gonna do that put beside the point).
    Will this work?
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/173850579330
  10. UNCNDL1
    Shawn likes this.
Similar Threads - CHARGER COMPATIBLY
  1. CocoLoco
    584
