Charge Dell 9550 over USB-C Thunderbolt port
Discussion in 'Dell XPS and Studio XPS' started by Paloseco, May 19, 2017.
  1. Paloseco
    Paloseco Notebook Evangelist
    Would like to know if it's possible to charge the Dell XPS 9550 over Thunderbolt port.
  2. Paloseco
    I wonder if I can use QuickCharge 3.0 wall or car chargers with this laptop or the newer model 9560.
  3. _sem_
    _sem_ Notebook Evangelist
    Certainly - USB Power Delivery. WD15/TB16 do even with 130W which is more than USB PD standard (up to 100W). Some (but not all) 3rd-party laptop USB-C chargers and docks do too - compatibility is quite tricky despite the standard. The 9550 is known to accept 60W @ 20V 3A. Phone chargers won't work.
    Nope.
  4. custom90gt
    custom90gt Notebook Deity
    This has been answered a few times, but you need at least 65W to charge the 9550/9560 over thunderbolt. The Google 65W adapter is what I use.
  5. _sem_
  6. custom90gt
    I guess I should have said the adapter has to supply 19.5V for it to charge.
  7. Paloseco
    I've contacted today Dell UK using the live sales assistant, but they couldn't specify how to do it. Instead, they recommended me to contact tech support by phone since they don't have live chat.
    Qualcomm QuickCharge 4.0 supports Power Delivery, so in theory the same wall or car charger should be able to charge the smartphone and the laptop.
    Even if the charger provides as low as 36w, I think the computer should charge anyway, but slower. Where days exactly that there's a minimum wattage required?
    https://blog.banggood.com/how-quick-charge-qc-4-0-works-51328.html
    https://www.goandroid.co.in/qualcomm-quick-charge-4-0-coming-mid-year/60291/
  8. custom90gt
    It's not just a wattage requirement, it's a voltage requirement. Most cell phone chargers don't put out enough voltage to charge the XPS.
    Check out the PCWORLD link from _sem_ and it shows that only the 20v chargers worked on the XPS 13.
    *on edit* Quick Charge 4.0 is said to offer charging at either 5V (4.7A to 5.6A) or 9V (at 3A) - not going to work.
    pressing and _sem_ like this.
  9. tijo
    tijo Sacred Blame Super Moderator
    The XPS power circuit was designed for an input of 19.5 V (there's always some leeway, but not that much and I wouldn't go over 19.5 V) and it will also draw a certain amount of power to charge the battery and more if it is powered on. Don't try a 19.5V 15 W charger either, you're asking for a fire.
    pressing likes this.
  10. Paloseco
    They are orienting Quick Charge towards small devices only, thus removing the higher voltages like 20 volts.
    http://m.gsmarena.com/quick_charge_40_may_provide_up_to_28w_of_power_smartly-blog-21560.php
