changing screen to portrait mode
Discussion in 'Accessories' started by atyrrell, Mar 15, 2007.
  1. atyrrell
    atyrrell Notebook Consultant
    I have an hp nc6000 and using 2 19 inch lcds with it when its docked. I have two multisync 1980sxi monitors that both pivot 90 degrees to portrait mode. I would like to put one in portrait mode to use for word and internet. How do i get the image on the screen to rotate with the monitor? Im using vista ultimate if it matters.
  2. gohanssjn
    gohanssjn Notebook Evangelist
    What video card? I know that you can do a 90 rotation in the NVidia drivers.
  3. nquach
    nquach Notebook Consultant
    Newer video cards usually have this function built into the Control Center application for the video card. If you've only installed the bare video drivers, look for additional support applications. Otherwise you can run PivotPro (www.portrait.com) or similar to do the rotation.
    Good luck.
  4. lukealexander
    lukealexander Notebook Evangelist NBR Reviewer
    If you have an ATI card, you can download ATI tools, which allows you to do a variety of cool things, including rotating the screen.
  5. dragonesse
    dragonesse Notebook Deity
    I'm pretty sure you can do it through windows display properties too. I remember someone at work doing it by accident once and fixing it that way.
  6. atyrrell
    i was able to download ati catylist and that has enabled me to switch back and forth. thanks for the help
