CF52 Power LED Light
Discussion in 'Panasonic' started by Jackamundo, May 9, 2018.
  1. Jackamundo
    Jackamundo Newbie
    Can you please shed some light on this for me, when I turn my laptop off the LED indicator power light stays on?? Even if I remove the battery and instert it back in the light comes back on.. nothing else is running ie the fan, and when I power back up it starts from an off state? Can you please help or give me an idea of why this is happening? Thanks
  2. Shawn
    Is it off or hibernating?
    when it starts, do you see the blue screen with white Panasonic on it?
    Jackamundo likes this.
  3. Jackamundo
    Jackamundo Newbie
    As far as I’m aware it is off. When I start it back up the blue screen with the white Panasonic sign comes up. Say even when I take the battery out and pop it back in the light comes on. The light that comes on is above the keyboard.
  4. Shawn
    There is a setting in the BIOS about the light I think.
  5. toughasnails
    What is the full model number of your 52.
    ( CF-52?????? )
    UNCNDL1 and Shawn like this.
  6. User32
    User32 Notebook Evangelist
    That's for the battery, flashing/on continious.
