CF31 questions.
Discussion in 'Panasonic' started by adamwest436, Dec 9, 2014.
  1. adamwest436
    adamwest436 Notebook Evangelist
    Thanks again in advance.
    Hard drive is now supposed to be here tomorrow. Wish me luck. Any how to's for the corner repair would it be worth sending it off to one of you experts?
  2. CWB32
    about repairing that cracked case near the power connector ...
    one can use "JB weld" or a good quality epoxy to ensure integrity against moisture and dust intrusion , but it will do little good as far as physical strength goes .
    it should be possible to drift the two sections back into alignment and then carefully drill small holes on both sides of the crack and case bottom to accommodate a small "fish plate" with matching holes that bridges the top/inside of the crack .
    the holes in the fish plate can be tapped to match the screws or small matching nuts can be used .
    a small hole should be drilled at the end of the crack to prevent "running" .
    there is an "aluminum solder" available .
    (not to be confused with that model airplane cement that has aluminum powder in it ... worthless crapola)
    however , this requires the area to be soldered to be scrupulously clean and the application of heat that will destroy the paint ...
    not to mention the disassembly required .
    more pictures of the bottom side of the crack would be helpful .
  3. Shawn
    TIG weld it...:eek:
  4. adamwest436
    Lol damn didn't want to do a full tear down. Better pics as in from the inside of the case?
  5. adamwest436
    Tried to take pics of it, looks like it's on the crease and possibly not intrusive as it looks. Some of the screws didn't like the idea i was removing them. This is gonna be a fun tear down. Gotta call and find out about my hard drive as it is still scheduled for delivery on 13 of this month and hasn't left the state it originated in.
  6. adamwest436
    Had HQ video but only contains me trying to hold the camera still,focus and peel back the weather stripping to take the 1st pic.
    The silver/white line in 1st pic is the 1 tear and the 2nd one shows like a black foam/mesh material not similar to the one around the ports.
  7. adamwest436
    It's moving again! Yes! Waiting on parts suck.
    Date & Time Status of Item Location
    December 16, 2014 , 10:25 pm Departed USPS Facility LOUISVILLE, KY 40231
    Your item departed our USPS facility in LOUISVILLE, KY 40231 on December 16, 2014 at 10:25 pm. The item is currently in transit to the destination. Information, if available, is updated periodically throughout the day. Please check again later.
    December 16, 2014 , 5:10 pm Arrived at USPS Facility LOUISVILLE, KY 40231
    December 10, 2014 , 2:19 am Arrived at USPS Origin Facility TAMPA, FL 33605
    December 9, 2014 , 5:03 pm Picked Up TAMPA, FL 33637
    December 8, 2014 , 8:44 pm Shipping Label Created TAMPA, FL 33647
    December 8, 2014 Pre-Shipment Info Sent to USPS
  8. Shawn
    You think waiting sucks...Imagine the guys working for UPS this time of year...
    adamwest436 likes this.
  9. adamwest436
    Yeah when I was *UPS with a gun* Banks and stores had high demand to get change and remove excess cash asap. That was good overtime and paycheck every Friday. Christmas route was guaranteed 6 hours overtime plus time and a half.
    Either way, hard drive should be here very soon granted someone already showed up with a box toying with my emotions! LOL!
    Picked Up
    TAMPA, FL 33637
    December 19, 2014 , 8:25 am
    Out for Delivery
    CLEVELAND, OH 44118
  10. adamwest436
    I guess I didn't hit send, package lost again. Something told me to order a 2nd caddy empty.
