CF31 questions.
Discussion in 'Panasonic' started by adamwest436, Dec 9, 2014.
  1. ohlip
    ohlip Toughbook Modder
    Its ok. there is no need for an extension adapter.
    ohlip
    adamwest436 likes this.
  2. adamwest436
    adamwest436 Notebook Evangelist
  3. toughasnails
    There you go...was hoping Teo could answer that for you.
  4. adamwest436
    Wow replied same time I'll go ahead and get it then.
  5. adamwest436
    It's here, and yep it's cracked.
    Took a few 29 vs 31 shots as well.
  6. adamwest436
    Oh yeah...so after ordering the wireless card I get the 31 say about 30 mins later.
    Open it up and..... someone help me understand this inside?
    This switch that lights up when on and flashes then goes off when switched to off..
  7. ohlip
    Base on the picture, you already have the WLAN card. The switch is for wireless system. Unfortunately you don't have Bluetooth, GPS and broadband modem but as I said you already have the WLAN.
    Switch it on and look on the bios if it also enable then let windows(win 7) install the driver for you. That is the location of all the add on option(GPS, Bluetooth, WLAN and WWAN).
    ohlip
  8. Shawn
    It has a WLAN card (wifi) but it does not have a WWAN card..
  9. adamwest436
    WLAN is WiFi and WWAN is Cellular?
    Hard drive and caddy is lost via Fed EX. It was suppose to be here Saturday. Also no word back from Rob, I sent a PM to see if he had the DVD for it.
  10. toughasnails
    Yes we do have it. Incoming PM
