CF31 and Bluetooth Cards
Discussion in 'Panasonic' started by jtr8178, Mar 18, 2018.
  1. jtr8178
    jtr8178 Notebook Enthusiast
    I have around 150 CF31 units that are missing the bluetooth cards. Looking at some MK1 and MK2 models, we find the part #'s (DFUP2007ZA(4) and DFUF1807ZB(4)) ... Heartland wants almost $130 for the card and $7 for the antenna. I'm find with the antenna pricing, but $130 per card is a bit steep. Does anyone have alternative suggestions? Will and Bluetooth card from any CF31 model work for me? Basically, I'm looking for some alternatives to spending over $20k with Heartland.
  2. toughasnails
    UNCNDL1 and Shawn like this.
  3. Shawn
    I'm with Toughasnails.
  4. User32
    User32 Notebook Deity
    Or, get a bunch of Intel 6235 cards and place them in the WWAN slot if you really want BT.
  5. jtr8178
    So I would just need this card in lieu of the normal wifi card? I'm assuming there is a bluetooth antenna cable I would need to connect to it as well then?
  6. User32
    Yes and no, if you can find a 6235 that works in the WLAN slot you replace the original WLAN card with it. If it doesn't work, take out the WWAN card and put it in it's place.
    Works for me, although i'm thinking of going back to Wireless N on my CF-31 because it doesn't do much speed wise.
  7. Shawn
    I strongly suggest that if you plan on reselling these 150 units that you do it right with the proper Bluetooth card.
    Otherwise you WILL end up with a lot of angry customers and returns to pay out.
    I have bluetooth only cards that will fit in the WWAN slot, BUT when your customers wants bluetooth AND 4g WWAN, he will be p*ssed that he loses bluetooth.
    Bite the bullet and do it right if you are selling them.
    If they are for your own use then the mini bluetooth usb is the quick answer.
    The 6235 as a replacement in the wifi slot will not give you bluetooth. Been there tried that with MANY cards of all brands.
    A wifi/bluetooth card in the wwan slot will get bluetooth but that card will not get wifi. You need to leave the orginal card in also to have wifi and bluetooth in my tests.
    toughasnails likes this.
