CF30 mk3 gps ufficial intall but not work ?
Discussion in 'Panasonic' started by junglew, May 4, 2017.
  1. toughasnails
    Sure can when I get home. I am going to close the other thread for now.
    Shawn likes this.
  2. CWB32
    is that a picture of his cable ? eeewww !
    that looks like what happened to my '30 when i was mucking about with the gps stuff , just after i joined here (my cable did not look as bad as his) .
    perhaps the bad cable took out the fuse i am referencing .
    i am saying that if the cable does not correct the problem , a popped fuse might just be the answer , or at least near the top of the list .
    it is very easy to mess up with those cables and take out a fuse .
    Shawn likes this.
  3. ohlip
    ohlip Toughbook Modder
    You don't need to buy a ribbon cable from another farther pond, Lol.. Just look to your old stuff that has morethan 12 conductor and then cut it out as long as they have the same pitch. But pay attention to cable orientation as picture.
    ohlip
    SHEEPMAN!, UNCNDL1 and kode-niner like this.
