CF30 Internal USB
Discussion in 'Panasonic' started by Knightofoldcode, Nov 7, 2016.
  1. ADOR
    ADOR Evil Mad Scientist
    The one I had inside of my CF-30 worked fine, I only used the usb port for Bluetooth though. It showed up as it was suppose to.
  2. Knightofoldcode
    Knightofoldcode Notebook Guru
    I have tried a wireless mouse dongle, thumb drive, and memory card reader. Nothing works.
    I'll attempt to contact maker.
    Thanks!
    Knight.
  3. ohlip
    ohlip Toughbook Modder
    Try to ground the gps in line to activate the usb port or look on bios under serial if gps is active/enable eventhough without the presence of gps module.
    ohlip
    Shawn and onirakkiss like this.
  4. Knightofoldcode
    @ohlip
    This CF30 has OEM GPS, and OEM Bluetooth, both enabled, and working properly.
    Knight.
  5. Knightofoldcode
    The people at Custom-Toughbooks suggested a BIOS reset. I have done that, and no change.
    Also, just for a check, I booted into a live version of Linux, and used a wireless mouse dongle to test. The wireless mouse worked fine on both the native USB ports, as well as a PCMCIA <-> USB adapter.
    At this point I'm thinking somehow the USB connection on the WWAN sled is disabled somehow by the ToughBook itself, not by Windows or Linux.
    Knight.
  6. SHEEPMAN!
    SHEEPMAN! Freelance
    I'm curious to see two things.
    In Linux terminal do
    Code:
    lsusb
    ....and please post it. Should be less than ten lines. Cut and paste from terminal if possible. Like this...if folks are paying attention they will see this is at least a CF-31MK2. (the USB 3.0):)
    sev@se1-CF-30 ~ $ lsusb
    Bus 002 Device 004: ID 8087:07da Intel Corp.
    Bus 002 Device 003: ID 0430:0532 Sun Microsystems, Inc.
    Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 001 Device 003: ID 1199:9041 Sierra Wireless, Inc.
    Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 003 Device 003: ID abcd:1234 Unknown (This is a unmarked 4G thumb drive)
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    The other one is
    Code:
    dmesg | grep input
    That will be a bit longer.
    Thanks
  7. Knightofoldcode
    Sure.
    Here is the lsusb when the wireless mouse dongle is plugged into the USB port next to the power port.
    Code:
    root@kali:~# lsusb
    Bus 006 Device 004: ID 0424:2503 Standard Microsystems Corp. USB 2.0 Hub
    Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 004 Device 002: ID 044e:3001 Alps Electric Co., Ltd UGTZ4 Bluetooth
    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 003 Device 002: ID 0430:0530 Sun Microsystems, Inc.
    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 005 Device 002: ID 0951:1665 Kingston Technology Digital DataTraveler SE9 64GB
    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 001 Device 002: ID 045e:00e1 Microsoft Corp. Wireless Laser Mouse 6000 Reciever
    Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Here it is with the same wireless mouse dongle removed, and plugged into the internal WWAN USB Breakoutboard.
    Code:
    root@kali:~# lsusb
    And here is the results from display message: *Note, Wireless mouse was plugged in during boot into the USB port next to the power port. When booting while plugged into USB Breakoutboard, no status messages regarding wireless mouse are present.
    Code:
    root@kali:~# dmesg | grep input
    [    1.781924] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
    [    2.726740] input: Fujitsu Component USB Touch Panel as /devices/pci0000:00/0000:00:1d.0/usb3/3-2/3-2:1.0/0003:0430:0530.0001/input/input9
    [    2.727096] hid-generic 0003:0430:0530.0001: input,hidraw0: USB HID v1.00 Device [Fujitsu Component USB Touch Panel] on usb-0000:00:1d.0-2/input0
    [    3.466797] input: PS/2 BYD TouchPad as /devices/platform/i8042/serio4/input/input8
    [   11.720721] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input10
    [   11.751448] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input11
    [   11.751729] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input12
    [   12.006762] input: Panasonic Laptop Support as /devices/virtual/input/input13
    [   12.884375] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input14
    [   12.885055] snd_hda_codec_analog hdaudioC0D0:    inputs:
    [   12.955282] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
    [   12.956141] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
    [   12.956207] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
    [   13.639771] input: PC Speaker as /devices/platform/pcspkr/input/input18
    [   15.662630] input: Microsoft Microsoft Wireless Optical Mouse\xffffffc2\xffffffae 1.00 as /devices/pci0000:00/0000:00:1e.0/0000:0e:00.0/0000:0f:00.0/usb8/8-2/8-2:1.0/0003:045E:00E1.0002/input/input19
    [   15.665757] hid-generic 0003:045E:00E1.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft Wireless Optical Mouse\xffffffc2\xffffffae 1.00] on usb-0000:0f:00.0-2/input0
  8. Shawn
    Here is a simple idea.
    Is the flat cable going to the new board inserted fully and the proper direction?
  9. CWB32
    hmmm ...
    let me get this straight (in order to avoid error - ha !) ... and something to try in the process of elimination .
    you say that nothing works on the usb port you want to use ?
    have you tried using a dmm to check for the presence of +5VDC and/to ground ?
    ... the correct "pins" will be defined in the schematic ... these are not to be confused with the data +/- lines .
    i was working on the innards of a '52 dabbling with an infernal usb connector ... everything was working ok and then suddenly , things were not working ...
    yeppers ... popped a fuse that is about half as big as a small grain of rice .
  10. SHEEPMAN!
    SHEEPMAN! Freelance
    Breakout board, cabling, or fuse.
    Like Teo said the ground on the GPS IN would light up the GPS in bios.....but since you already have that.....hmmmm? It probably grounds through the break out board....where are you getting your 5v again? It wouldn't be on the same "circuit" as the GPS? Sorry, thinking out loud. Disregard.
    One interesting thing about the sled....I used a connection on the pcb in the sled one time to power a GPS (OEM type). It surprised me and worked in a CF-29 also...but whined that power was low....then worked anyway. Plug and play with the right cable. (The little one in the sled)
    You need one of my MK1 (CF-30) to play with. They're OEM GPS/Verizon WWAN (sled). Do you want to borrow one to experiment on?
    I hesitated to say but I'm older than I was yesterday so I don't get embarrassed...I set a cable in place one time in a hard drive one hole to the left. Lucky it didn't let the smoke out.
    Good luck.
    Jeff
