CF19, Mk6 Thermal pads
Discussion in 'Panasonic' started by Liteace, Jul 8, 2018.
  1. Liteace
    Liteace Notebook Consultant
    Ive dismantled my CF-19, Mk6 to try and find the hot running problem and have a couple of questions for you guy's.
    The 2 pads that are there does anyone know what I need to order to replace them, is there only meant to be 2 pads and how can I remove the heatsink from the body of the laptop, Ive removed the 10 screws but its stuck, is there anything hidden ?
    Thanks
  2. blysk
    blysk Notebook Guru
    I normally change such heat pads for thermal paste, I did that in a lot of laptops.
    Normally paste is far better than such a standard pad.
    Liteace likes this.
  3. Liteace
    Sorry for the stupid question, I though the pad was designed to take up the gap between heatsink and chip
  4. I58SR
    I58SR Notebook Consultant
    Liteace likes this.
  5. Shawn
    @Liteace
    Let me see if a service manual lists the thickness's needed.
    service manual for mk5 is easier to read. It does not list thickness.
    Liteace likes this.
  6. Shawn
    Had a empty mk6 chassis here.
    Best measurement I got with the digital calipers is 1.5mm thick for both pads.
    Liteace likes this.
  7. ADOR
    ADOR Evil Mad Scientist
    If you are changing them go look at gaming thermal pad replacements. They have some made of better materials that cool a lot better than stock. Well they do on the Mk1 and 2 versions. Haven't had a need yet to try it on the Other versions. I do think I would be too big of a gap with paste as well.
    Liteace likes this.
  8. Liteace
    Thanks Guy's Ill see what I can get, does the heat tube to frame/chassis have any pads, paste or thermal epoxy?
  9. Shawn
    very thin pads under it.
  10. Liteace
    Ive removed the screws and its stuck, the copper tube is free its the plate that wont move, I think I best leave it stuck just incase
