cf w8 linux mint 17 cinnamon no sound
Discussion in 'Panasonic' started by nicklos, Oct 11, 2014.
  1. nicklos
    nicklos Notebook Enthusiast
    hi
    i am a new owner of a cf w8 ewezzam and tried to install mint 17 cinnamon on it everything works out of the box but the sound doesnt
    i tried many things
    esp
    here
    and
    here
    codes
    Code:
    q@q-CF-W8EWEZZAM ~ $ cat /proc/asound/cards
     0 [Intel          ]: HDA-Intel - HDA Intel
                          HDA Intel at 0xf6a20000 irq 47
    q@q-CF-W8EWEZZAM ~ $ head -n 1 /proc/asound/card0/codec*
    ==> /proc/asound/card0/codec#0 <==
    Codec: Analog Devices AD1883
    ==> /proc/asound/card0/codec#1 <==
    Codec: Conexant ID 2c06
    Code:
    q@q-CF-W8EWEZZAM ~ $ lspci | grep -i audio
    00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
    Code:
    q@q-CF-W8EWEZZAM ~ $ aplay /usr/share/sounds/alsa/Front_Center.wav
    Wiedergabe: WAVE '/usr/share/sounds/alsa/Front_Center.wav' : Signed 16 bit Little Endian, Rate: 48000 Hz, mono
    i have installed win7 pro 64bit too the sound works fine on it, so it is no hardwareproblem
    does anyone succed in getting the sound worked under mint cinnamon quiana?
    thx for your answers
  2. kode-niner
    kode-niner Notebook Consultant
    I don't run Mint, but try to bring up alsamixer and see if all the levels are o.k. and not muted. You might have to hit F6 and select your sound card to see all channels.
    Are you running pulseaudio?
  3. nicklos
    this was the first i did alsamixer unmute
    i tried pulsaudio aswell no changes
    do you run linux on your book?
    and what distribution and is audio working?
  4. nicklos
    so today i tried a life cd and sound worked
    so installed mint 17 cinnamon and sound already worked
    the problem is solved but not solved too, cause i do not know what the root of this problem was
  5. kode-niner
    Wait, what?
    Anyway, glad it works. I don't own a W8 but I have a bit of experience with sound problems on Linux. Right now I'm running Debian on most of my systems.
    cheers!
