CF U1 dock..pins for USB port.. help needed- NEC 0720113GK
Discussion in 'Panasonic' started by Shawn, Oct 11, 2018.
  1. Shawn
    I got some internal photos of a U1 dock.
    I want to know what dock pins are the usb port.
    Probably also a pin that grounds out to enable the dock/usb port.
    I figure the NEC 0720113GK is the usb hub.
    Once we find the dock connector usb pins, I can add an usb port where the barcode reader normally goes.
    I can get higher res photos if needed.
    resized  Image00009.jpg resized  Image00007.jpg resized  Image00002.jpg 20181008_163544crop.jpg
  2. Shawn
  3. Shawn
    Better photos. These are still resized. I can email the full res images if needed.
    The 30 pin FFC with the F4 5a marked fuse the the one that goes to the dock connector.
    The larger one goes to the extra battery ports.
    CN 14 is unpopulated. CN 11 goes to the battery LED's
  4. ADOR
    ADOR Evil Mad Scientist
    I need to look when I get home from work i have a full size u1 dock at home.
    Shawn likes this.
