CF-U1 2nd / second usb port
Discussion in 'Panasonic' started by Shawn, Oct 27, 2018.
  1. Shawn
    Used the fingerprint reader port.
    BEWARE it is 3.34 volt and NOT 5 volt.
    5 volt is standard for usb ports.
    3.34 volt seems to work fine for my wireless mouse.
    CF 19 fingerprint wiring is what I used.
    The enable pin needs grounded in order for the BIOS to enable the FPR port.
    The one corner of the new usb port needs trimmed. I think it could be trimmed a bit more than I did.
    I used a 12 pin ffc and breakout because I already had them.
    An 8 pin breakout and ffc cable is all that is needed.
    CF 19 FPR schematic
    as promised
    resized  Image00003.jpg resized  Image00004.jpg resized  Image00005.jpg resized  Image00006.jpg
    t456 and toughasnails like this.
  2. toughasnails
    Very nice job Shawn
  3. Shawn
    Thanks!
  4. Shawn
    Voltage test.
