CF- Model Number / Letters meaning.
Discussion in 'Panasonic' started by scpres, Oct 6, 2018.
  1. Shawn
    All you can do is wait and see.
    I imagine the biggest thing is WIFI. Some Gov't models had WIFI totally disabled in the bios. That can sometimes be cured with a usb stick or a PCMCIA card. Crossflashing the bios can be next to impossible on a mk3. I have had to remove bios chip and replace it on certain models. The CF31 mk3 is on that list.
    Seller did say he had Win7 installed on it.
    The info page shows 4gb ram. Those are both good signs.
    toughasnails likes this.
  2. scpres
    scpres Notebook Guru
    Yeah shawn.
    He sent the CF-31 now! and will be arrivibg Friday// Ill keep you updated....
    I have a project now I flash Windows 10 pro in CF-U1 MK2 Ultra.. and its amazing... lol
    ALl works
    Yeah base on the images the CF-31 has windows 7 Pro x32 bit and activated. Regarding the bios I really hope that it doesn't have a password.. Or else im stuck in x32 bit.
    It has a much powerful CPU too.
    Back in 2 years ago I remember I have a HP ProBook which has a bios password but I manage to remove through HP software too.
    I don't know in Toughbook though. Hopefully it doesn't have a password.
  3. scpres
    Hello Guys,
    It arrived today... and its amazing!!!!!!!!!!!!!!!!
    NO BIOS PASSWORD
    WITH ATI Discreet VIDEO
    WIFI
    Ill show pics later
    500GB HDD
    4GB RAM
    AS NEW!!
    toughasnails and SHEEPMAN! like this.
  4. sunrk
    sunrk Notebook Evangelist
    Sounds like you might have scored well. I'm happy with Mk 3 CF-31 that i got from a local Oz seller (reputable). Mk 4's hadn't really come available in the used market here at the time, but maybe they are now.
  5. scpres
    Heres some pics
    No DVD which i can byuy off ebay fo 50 bucks
    AS NEW Condition with 780 hRS in bios
    With Discreet video graphics...
    And will clean install windows 10 1809 on my free time.....
  6. scpres
    Hello just a question guys.
    I am planning to upgrade the ram of CF-31 Mk3 that i have. I tried to open the ram cover and boy its tight. I have use a smaller screw driver that stuff my screws and then use the right size so im lucky i did not damage it.
    I installed my spare ram for my CF-19 Mk7 (CF-WMBA1304G) but the specs is different from the original installed inside. please see images below.
    I have not experiencing any problem so far and planning to clean install windows 10 on my rdo.
    Can anyone please help regarding the difference between the two ram?\
    Also there is a copper cover on top of the original so i just put my spare on top of it because i dont want to unscrew it..
    Seems like this Toughbook screws has never been removed or open.
  7. Shawn
    Copper plate goes on top not in between.
  8. Shawn
    The memory chips are not matched. They have a different density and speed. There is a chance that you will get random errors and lockups under heavy useage.
  9. scpres
    Thanks Shawn for the reply. Would that be an issue about the copper plate? is that a heat absorber?
    because i dont want to open it again.;
  10. Shawn
    Could case heat, shorting or radio frequency interference issues.
    It's a 15 minute job to tear it apart.
    Take the time and do it right.
