cf-h2 sata connector compatibility
Discussion in 'Panasonic' started by kschewe, Mar 1, 2020.
  1. kschewe
    kschewe Notebook Enthusiast
    Does anyone know if the connector for the cf-h2 is the same for other models like the cf-31 52 cf-19 etc.
    Not concerned about the caddy. just the ribbon connector, sata to proprietary connection.
    I just make custom caddy. Been using msata as drives for a few of my models.
    thanks
  2. Shawn
    photos would help.
  3. kschewe
    I will post one when it arrives from ebay thanks. My guess its most models are the same. I can only see poor angle pics of motherboards on ebay. When it arrives i can try cf19 and cfc2. It would be nice if they work since its easy to find. s-l1600.jpg
  4. Shellback
    Shellback Notebook Geek
    I believe you are correct that the connector to the motherboard is the same for multiple models.
    Pictured are CF-19 and CF-H2 ribbon connectors. Hard to see in the pics that the motherboard connectors are the same, but they both will fit a CF-31 motherboard.
    Thanks for stirring up my curiousity! :)
    Philip
  5. Shawn
    While they may all look the same, some are wired differently.
    Yes I have tried to swap a few between models.
    Some do interchange. Some do not.
  6. kschewe
    i will check and see. i am thinking cables of the same years might be compatible. i will check and . it would be good to know since the caddys seem to be worth more then the whole machine. older ones like the cf-h2 i mean
  7. Shawn
    H1 and H2 caddies have always been pricey.
  8. kschewe
    i was lucky when i got my h2 it had the caddy and connector even though the ad said no drive which normally is no caddy. i did check though and maybe we can make a list one day. i checked the pins and compared 3 i have. h2 and c2 pins outs are the same even though they look different. I checked with meter. cf-19 is not the same as these. i am using cf-19 from mk1 on mk5. i would assume all the cf19 are the same though.
    very neat little machine. it has some off options. it came from a lab. panasonic should still make these with lastest gen hardware or android options
  9. Shawn
    thanks for the caddy info
  10. safn1949
    safn1949 I'm sure I'm on the wrong planet
    I had a dozen H1's and 4 H2's. Sold 3 mint H2's restored for $2800.:eek::D
    Piled the H1's on my pickup tailgate, took a photo and sold them all for $400 with 1 caddy. 2014, sold the red coca cola one to that prick Rob.
