CF-D1 info
Discussion in 'Panasonic' started by Shawn, Dec 22, 2018.
  1. Billiboy71
    Billiboy71 Notebook Enthusiast
    has anyone ever upgraded the processor? now I have installed a Celeron 1037U.
  2. Shawn
    Soldered to the board.
  3. Billiboy71
    ****... Ok, Thank You..
  4. Billiboy71
  5. Shawn
    D1 indicates mk1..D2 indicates mk2.
    Also the M10 at the end indicates a custom BIOS ordered by the original purchaser. Rarely can these custom BIOS's be upgraded.
    Good thing it stopped or you would have a brick.
  6. Billiboy71
    now I'm confused. CF-D1G / K should be MK2 and D1A is MK1. I also looked for the drivers / bios by model. Then I will call the support, see if they have an idea how I can get the bios update to run or is there another way!
  7. Shawn
    With your machine having Bios V2.50L11 M10, you will not get any standard bios update to work.
    M10 indicates a custom BIOS.
    Mine is a CF-D1DW200FZ-----BIOS number V1.50L10 M10
  8. Billiboy71
    I suspect the device was renamed to a Cf-D1. The seller has indicated that he has installed a new silver frame. I'll call Panasonic.
  9. Geraout
    Geraout Notebook Consultant
    For info
    Pics showing the WWAN & GPS antennas vs the standard model, and the position of the WWAN & GPS cards and connectors.
      File size:
      384.8 KB
      26
      File size:
      806.1 KB
      27
  10. Shawn
    Thanks for the photos
