CF-D1 info
Discussion in 'Panasonic' started by Shawn, Dec 22, 2018.
  1. Shawn
  2. Billiboy71
    Billiboy71 Notebook Enthusiast
    Only WWAN or other Modules?
  3. CLASSIF1ED
    CLASSIF1ED Notebook Enthusiast
    If it's wired as USB I don't see why you can't use it as extra USB port for things like Bluetooth or a Logitech Unifying receiver.
  4. Billiboy71
    Ok, Thank You
  5. Shawn
    You usually cant because the Panasonic BIOS prevents them from working.
    Been down this road many times. I have had some luck with a second wifi/bluetooth card in the WWAN slot. Intel 6235 I think.
    The only thing is that the bluetooth worked but the wifi did NOT in the WWAN slot. I have found a gps card that worked in the WWAN slot for a while.
    Normal laptops have usb AND PCIE wired on a mini PCIE (WWAN and WIFI card slot)Toughbooks do not.
    Toughbooks are not like normal laptops. Use the search tool and read.
    You can learn a lot that way.
  6. Billiboy71
    I can already tell that the Toughbooks are different from other laptops. installing Win7 x64 in the Uefi alone is difficult.
  7. CLASSIF1ED
    "Win7"
    "UEFI"
    There's your problem. Win7 does not support UEFI without CSM.
  8. Billiboy71
    what is the solution?
  9. CLASSIF1ED
    Enable CSM in the BIOS.
  10. Billiboy71
