CF-D1 Bluetooth doesnt work
Discussion in 'Panasonic' started by LumiaNutzer, Dec 21, 2018.
  1. Shawn
    WLAN (WIFI) does not use sim card.
    You can try the 6205 in the first slot and the 6235 in the second slot.
    I do not know if BT will work or not. It is an experiment.
    If it works, you will need to install a Bluetooth antenna of some kind.
  2. LumiaNutzer
    LumiaNutzer Newbie
    It doesnt function :(
  3. Shawn
  4. ohlip
    ohlip Toughbook Modder
    Good Morning, guys. Its been a long time! Anyway, to OP, On 7260 card. Try taped pin 20 and 51 and after install set the bios into default setting. Let see what happened.
    ohlip
    Shawn likes this.
  5. BaRRmaley
    BaRRmaley Notebook Deity
    Doesn't work on CF-19.
    I think these experiments are boring, let's disassemble something new :))
  6. LumiaNutzer
    LumiaNutzer Newbie
    I wanted to prevent this solution because of the dust and dirt in the workshop. This would require me to leave a protective flap open :/
  7. Shawn
    Hello Teo,
    Welcome back!
  8. Shawn
    This might be a dumb question, but is Bluetooth enabled in the BIOS?
    Did Bluetooth ever work on this unit?
    @BaRRmaley If you are bored, maybe get a couple Macs to work on? :eek2::elvis::biglaugh::biglaugh::biglaugh:
    BaRRmaley likes this.
  9. ohlip
    Try it first the one I suggested. There is nothing to lose. I've done it almost 50 times and it works to me from Toughbook to Getac PC. As I said after the installation, set the bios into default to recognized the BT. Don't listen to the people who has nothing to do, Lol....
    ohlip
    Shawn and BaRRmaley like this.
  10. ohlip
    Shawn, Whats up, man! Is Jeff still around?
    ohlip
