CF-53S LED Backlight went out.
Discussion in 'Panasonic' started by Psychowolff, May 5, 2018.
  1. Psychowolff
    Psychowolff Notebook Consultant
    I picked up a CF-53S but the LED Back light isnt working. It does boot to the setup screen and you can see it but there is no Backlight. Since it is the LED the chances of them going out is slim, so Im thinking the board maybe?? Anyone have input or experience with this issue or replacing the Lighting? Any help would be appreciated!! Thanks!
  2. Shawn
    Early 53's are kind of known to have video/backlight issues.
    Touchscreen models seem more prone to problems.
    Sometime you get lucky and the cable is the issue.
    Mine was the motherboard. I parted the whole thing out.
  3. Psychowolff
    Well, thats not what I was hoping to hear! LOL I'll tear into it when I get home and see whats there to see...
    It is the touch screen model and it has the same i5 as my 31W, was hoping it might be a simple fix. Well, Im still hoping that it is.
    Thanks Shawn, hope everything is going well with you!
  4. Shawn
    day by day for me.
    Keep us posted
  5. safn1949
    safn1949 I'm sure I'm on the wrong planet
    I hate to agree but...bad motherboard I'm betting. Shawn, either you or Larry had the photos of the burned spot on a 53 motherboard didn't you?
    I seem to remember that, blown fuse I think.
  6. Shawn
    yes, I have photos somewhere
  7. toughasnails
    Did you try connecting it to a flat screen TV to see if it works ?
  8. Shawn
  9. safn1949
    Ouch.:D
    I tossed one that did the same thing if I remember correctly,after I stripped it of course.
  10. Psychowolff
    I haven't tried to connect it to an external screen yet, I know the screen works as you can see the setup screen if you hold it at the right angle but it doesn't brighten up when you hit the FnF12.
    Those pics make it look like You can't put a penny in place of the Fuse like I do at Home. LOL
    Shawn FYI, My CF31W is running fine with 12GB of memory. Only had the one 8GB card I swiped from my brothers gaming system. Still going to be a while before I can afford a pair of 8G chips for myself, but 8G is plenty anyways.
    Shawn likes this.
