CF-53J microphone
Discussion in 'Panasonic' started by locksmth, Jul 31, 2019.
  1. locksmth
    locksmth Notebook Enthusiast
    I would like to install a microphone in my CF-53J. I don't need a web cam, but I would be happy to install one at a decent price, just never see them for sale. I really only need the mic. Any ideas on how to do that?
  2. evenflow153
    evenflow153 Notebook Consultant
    Is it a 31 or a 53? I see 31 and in the title it’s 53. Sorry I’m a bit agitated at the moment
  3. locksmth
    My bad. It is a CF-53. I have corrected my post. My CF-31 already has a web cam/microphone in it. Thanks.
    evenflow153 likes this.
  4. SHEEPMAN!
    SHEEPMAN! Freelance
    Take a glance at some of the stuff on adafruit. I peeked at it the other evening and became somewhat distracted for a couple hours.
    You have been warned. :)
    Is your CF-31 camera and mike in the lid? How about opening the lids on both and then sitting there staring at the components for a bit. Be advised there is 12V (maybe 5V) open voltage in the lid when the computer is off. Please pull the batteries first and cycle the switches to drain residual power.
    G'luck.
    toughasnails and evenflow153 like this.
  5. Shawn
    The CF 53 has the mic built into the webcam.
    It was an option.
    Search for CF 53 webcam.
    I found one for $199.00
  6. locksmth
    I have been looking. Only finding one online vendor so far. What is the video like?
  7. evenflow153
    possibly less than 720P
  8. locksmth
    I have one on my CF-31 and it is terrible. I was hoping if I have to buy one to at least get some quality this time.
  9. toughasnails
    If yours is bad check these 5 threads out below. Now this is for the CF-31 but I would send the seller and see if it might fit a 53 or have one for it.
    http://forum.notebookreview.com/thr...k3-installation-success.822433/#post-10837955
    http://forum.notebookreview.com/thr...that-are-a-good-match-for-a-toughbook.821007/
    http://www.tecrotech.com/#videot
    https://www.techtough.com/blog
  10. Shawn
    The quality of video in the Q1 is good. It all depends on what camera they used.
    I do not own a CF 53 anymore. My CF 53 did not have the camera to test.
Similar Threads - microphone
  1. etcetera
    240
