CF 53 mk4 WiFi BT Card replace-help
Discussion in 'Panasonic' started by eazydaz, Jun 12, 2020.
  1. eazydaz
    eazydaz Newbie
    Hello :) I have CF53-mk4, my wlan card was faulty, I replaced it with same type (Intel AC 7260 NGW. Now wlan work again, but bluetooth not, I dont see it in device manager. When I remove it and try with old card again bluetooth work I see it in device manager too, but new card nothing. Please where can be problem? I bought another card again, but still the same problem, wlan work but bluetooth not. In my bios and dont see anything about bluetooth.
  2. steve.steve
    steve.steve Company Representative
    You probably installed a Dell branded card. Does it have DPN on it?
  3. eazydaz
    eazydaz Newbie
    I dont know what is DPN ?? here is photo from cards, first from left in green ring is genuine, other two are these that I bought(used) on ebay.
  4. steve.steve
    Middle card is Toshiba, far right is Dell. I'm surprised the Toshiba card doesn't work for you.
  5. eazydaz
    eazydaz Newbie
    But Dell doesnt work too :( it is not possible make it working? or which one will be worked for 100%?
  6. steve.steve
    Buy a Panasonic specific card to have the Bluetooth and wireless work properly.
    UNCNDL1 likes this.
  7. Geraout
    Geraout Notebook Consultant
    I've had the same problem in the past.
    Is there a way to tell a Panasonic card from the label ?
  8. steve.steve
    Look for vendor specific part numbers. T part number for Toshiba. DPN or d/pn for dell part number.
  9. eazydaz
    eazydaz Newbie
    but it is impossible making it fully working when it is not from panasonic?
  10. steve.steve
    You could write your own efi bios driver or flash the WiFi card with a generic Rom. Easier to get the correct WiFi card
