CF-53 MK1 - bluetooth problems
Discussion in 'Panasonic' started by tuff, Sep 9, 2016.
  1. Shawn
    Yes my board appeared in the BIOS after I installed it. It is still in the BIOS.
    Optional kit makes no difference. Set it to 04 like mine if you like.
  2. tuff
    tuff Notebook Enthusiast
    just for fun I set the opt kit to 04 and WLAN appeared as an option, no bt and no bt functionality still...
    I am starting to think I have a bad bt module...
  3. toughasnails
    @Shawn @tuff does yours show up in Device Manager ? and what does it show up as ?
  4. Shawn
  5. Shawn
    Sadly it's not a time delay issue.
    Photos won't upload properly.
    When they do upload, they will show up until i leave the page and come back. Then all that shows is an empty thumbnail.
  6. Shawn
    Shows in BIOS and shows in device manager. Believe it shows as 3 different Bluetooth items in Device manager.
  7. tuff
    Hi, shows up in Dev Manager as "Bluetooth RFCOMM", says the device is working properly and the power state is on and full power.
  8. Shawn
    Try this
    Open the downloaded BT drivers with 7zip.
    Troll through the folders until you find the one with setup.exe and pinstall.bat in it.
    RIGHT click on setup.exe and Run as Administrator.
    Let us know if that installs any differently
  9. tuff
    Tried posting pic, same problem: posted until I left page, thought it was my doing. Thanks for the pics, that is exactly the way the module is in.
  10. Shawn
    No, it's not you.
