Cf 51 only runs on battery
Discussion in 'Panasonic' started by hinge, Mar 12, 2011.
  1. hinge
    hinge Notebook Enthusiast
    I have Mk2 that only runs on battery, power cord tested OK, resoldered power connecter on mother board, looking like MB is fried (this is my 2nd MB in this unit, 1st one the display blacked out and replacing MB fixed it, so now this , are the MB's pieces of sh** in these toughbooks?
  2. Driller
    Driller Notebook Evangelist
    don't know as much about the mk2 but the mk3 is a good deal as for the cpu swap to a core2duo is concerned. sometimes you can get a reasonable deal on the mk3's from buybest15 or buybest13 and then up the ram to 4gb pc2 5300 and get a hdd caddy and go for a samsung ide 160gb hhd or the 320 wd wd3200beve which works well. it adds up quick if you assemble the parts or if you luck up and find a complete unit and just add the ram, cpu, hdd. either way alot of the forum members that use the cf-51 core duo with upgrades are pleased with the performance. I've been fortunate so far with 6 of them.........Driller
  3. toughasnails
    I have had many MK1's and MK2's and never had any problems with them at all. Great laptop and as Driller said the MK3 is even better :D
  4. hinge
    Driller, do I contact bestbuy 15, or does he just post in buy and sell forum
  5. Shawn
    bestbuy 13 and 15 are Ebay sellers.
  6. John229
    John229 Notebook Geek
    I had this happen on a MK3 I got off eBay. Look on the bottom of the MB at the power connector and follow the + trace and look for a possible cold solder joint. On my Mk3 it was at choke, L103 as I recall. In fact the Mk3 uses two chokes and one was missing.
    I wonder if there is a little bit of flex in this area if the power connector is pressed very hard, or the cord gets jerked. :confused:
    Anyway, the issue was the same, ran on battery only, works great now!
  7. hinge
    John, that was it on mine also, except its labeled L810 ( Mk2 and Mk2LL boards). I just touched it with a probe and it fell right off the board. I'll probably messed it up when I try to resolder it, thanks
  8. John229
    Hinge, It was a little touch and go when I redid mine, but it's still working just fine!
  9. hinge
    I soldered the inductor back on and its up and running OK now, THANKS again, John, you saved me from buying another motherboard
  10. John229
    Good Deal!! Glad when I get something right!!
