CF-31WFLAXLM - Dual Pass (Upper WWAN / Lower Selectable)
Discussion in 'Panasonic' started by UNCNDL1, May 18, 2019.
  1. UNCNDL1
    UNCNDL1 Notebook Deity
    Back on track to this 31 using Linux for the moment. Jeff suggested going into mouse settings (using Mx18.2) which I did (see screenshot)
    however scrolling through this forum posts works okay, but the mouse on a screen moving around seems "sticky", "laggy", can't describe it much better and wondering if there is another tweak to make it more sensitive?
  2. UNCNDL1
    Lowering the sensitivity way to the right seemed to help a bit.
    Here's a shot of the working system with 18.2
    Code:
    System:    Host: mx Kernel: 4.19.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
               Desktop: Xfce 4.12.3 Distro: MX-18.3_x64 Continuum Apr 7  2019
               base: Debian GNU/Linux 9 (stretch)
    Machine:   Type: Laptop System: Panasonic product: CF-31WFLAXLM v: 004 serial: <filter>
               Mobo: Panasonic model: CF31-4 v: 1 serial: <filter> BIOS: American Megatrends
               v: 4.00L14 date: 07/25/2014
    Battery:   ID-1: BAT1 charge: 61.7 Wh condition: 81.1/91.0 Wh (89%) model: Panasonic CF-VZSU46
               status: Discharging
    CPU:       Topology: Dual Core model: Intel Core i5-3340M bits: 64 type: MT MCP arch: Ivy Bridge
               rev: 9 L2 cache: 3072 KiB
               flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21551
               Speed: 1198 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1198 2: 1546 3: 1608
               4: 2009
    Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Matsushita driver: i915
               v: kernel bus ID: 00:02.0
               Display: x11 server: X.Org 1.19.2 driver: modesetting unloaded: fbdev,vesa
               resolution: 1024x768~60Hz
               OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 18.2.6
               direct render: Yes
    Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Matsushita
               driver: snd_hda_intel v: kernel bus ID: 00:1b.0
               Sound Server: ALSA v: k4.19.0-1-amd64
    Network:   Device-1: Intel 82579LM Gigabit Network vendor: Matsushita driver: e1000e v: 3.2.6-k
               port: f080 bus ID: 00:19.0
               IF: eth0 state: down mac: <filter>
               Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel port: f040
               bus ID: 09:00.0
               IF: wlan0 state: up mac: <filter>
    Drives:    Local Storage: total: 465.76 GiB used: 9.06 GiB (1.9%)
               ID-1: /dev/sda vendor: Seagate model: ST500LM021-1KJ152 size: 465.76 GiB
    Partition: ID-1: / size: 455.45 GiB used: 9.06 GiB (2.0%) fs: ext4 dev: /dev/sda1
               ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
    Sensors:   System Temperatures: cpu: 42.0 C mobo: N/A
               Fan Speeds (RPM): N/A
    Repos:     Active apt repos in: /etc/apt/sources.list.d/antix.list
               1: deb http://la.mxrepo.com/antix/stretch stretch main
               Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
               1: deb http://ftp.us.debian.org/debian/ stretch-updates main contrib non-free
               Active apt repos in: /etc/apt/sources.list.d/debian.list
               1: deb http://ftp.us.debian.org/debian/ stretch main contrib non-free
               2: deb http://security.debian.org/ stretch/updates main contrib non-free
               Active apt repos in: /etc/apt/sources.list.d/mx.list
               1: deb http://mirrors.rit.edu/mxlinux/mx-packages/mx/repo/ stretch main non-free
               Active apt repos in: /etc/apt/sources.list.d/spotify.list
               1: deb http://repository.spotify.com stable non-free
               No active apt repos in: /etc/apt/sources.list.d/various.list
    Info:      Processes: 204 Uptime: 4m Memory: 3.72 GiB used: 408.1 MiB (10.7%) Init: SysVinit
               runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.33
  3. Wyoming88!
    Wyoming88! Notebook Evangelist
    Good idea
    Hey @UNCNDL1! Need anymore help on this? I think that Ubuntu with out-of-the-box things might work. Ubuntu on laptops with touchscreens isn’t my choice. If someone made a 31 FAQ (btw yes I searched and there’s not one) MK4s came with Windows 7, Ubuntu works on them but there is no drivers for Ubuntu. Unless you use the program Wine for Windows programs. I don’t know if they could do drivers
