CF-31WFLAXLM - Dual Pass (Upper WWAN / Lower Selectable)
Discussion in 'Panasonic' started by UNCNDL1, May 18, 2019.
  1. UNCNDL1
    UNCNDL1 Notebook Deity
    Bought a project and would like to understand the configuration better.
    What does Lower Selectable mean? Also, what does Channel Limited mean?
    Yes, it was 95% off list price...
    ...Linux is good for what ails you...
    Lefty
  2. mklym
    mklym Notebook Evangelist
    Cleve,
    Lower selectable is referring to the lower, or bottom, of the 2 external antenna pass-through the unit is equipped with. Some unit have 1 pass-through. The pass-through is used with a vehicle dock to facilitate the use of an external antenna. In your unit the upper, or top, pass-through is dedicated to a WWAN card while the lower one can be dedicated to any wireless device you may install, including GPS.
    As for the Channel Limited, I think it is referring to the type of client the unit(s) can be marketed (sold) to. Rob can probably answer better than I.
    Shawn and UNCNDL1 like this.
  3. UNCNDL1
    Morgan, Thank you very much as you explain this very well. Last question (for now), What Mark is this 31?
  4. unclemack
    unclemack Notebook Evangelist
    Hi, I was curious and Google found the same configuration for sale - seller stated it was a Mark 4.
    Wyoming88! and UNCNDL1 like this.
  5. Shawn
    CF31W is a mk4
    UNCNDL1 and Wyoming88! like this.
  6. UNCNDL1
    Thanks very much.
    I’ve seen it listed as a III and IV
    I’ve never been very Mark savvy
  7. Shawn
    Neither have i, and I have a brother and also a co worker named Mark.
    Very little difference between a mk3 and mk4 anyway.
  8. UNCNDL1
    Hopefully a Linux distribution will work out of the box especially sound and touch
    Sent from my CF-M34
  9. Wyoming88!
    Wyoming88! Notebook Evangelist
    How I want my CF-28s to be when the ship in
  10. UNCNDL1
    Any 31 owners...what is part number of optical media bay dvd drive?
    Don’t want to purchase the wrong one as part for a 30 doesn’t fit.
    Best regards.
    Sent from my CF-M34
