CF-31 port replicator jack pinout.
Discussion in 'Panasonic' started by damanx, Sep 4, 2017.
  1. damanx
    damanx Notebook Guru
    Anyone have this info because I am curious which pins are for the HDMI output from the CF-31.
    Thanks!
    safn1949 likes this.
  2. tacosalad
    tacosalad Notebook Enthusiast
    Are you sure there is HDMI available in the docking connector? There have been very few changes to the docking connectors over the years to maintain compatibility.
  3. damanx
    The Panasonic CF-VEB311U has a HDMI connector on it.
  4. toughasnails
    Always remember Google is your friend. Took me no time to fine this.
    No
    Panasonic CF-VEB311U - Dock for Toughbook
    Product details
    Brand: Panasonic
    Port type: USB, HDMI, VGA, Serial
    Designed For: Panasonic Toughbook 29, 29 Air Force Only, 29 Arvada Police Only...
    The Panasonic CF-VEB311U desktop port replicator is perfect to use with CF-31 Notebook. This port replicator offers enhanced connectivity and safety for hassle-free work. It includes three USB ports, two serial ports, one VGA port, one HDMI port, one mic. - Desktop port replicator makes your work easier and more enjoyable with up-held connectivity and safety. - Suitable with Panasonic Toughbook CF-31, Panasonic Toughbook 29 Air Force Only and Panasonic Toughbook 29 STS Only. - Interfaces/ports: Three USB ports, two serial ports, one VGA port, one HDMI port, one microphone jack, one headphone jack and two RJ-45 ports. - Plenty of ports let you to plug most of your peripherals into while cable lock slot ensures safety of your notebook
    https://www.google.ca/search?q=CF-V...eXrBKuD0wLW5bHgBg#gws_rd=cr&idx=0&pie=plaji-i
    More details
  5. damanx
    Not sure how I can respond to this without sounding like a jerk because I am really not, but, if you notice the post above yours, I wrote about the CF-VEB311U dock, which I had previously found via google. That dock is the reason the title of the thread specifies the PINOUT for the CF-31 port replicator.
  6. Shawn
    Interesting that it lists those specific Cf 29's.
    Maybe those units have HDMI out on the docking port and the regular CF29's do not.
    I would like someone who has one of those docks to test it with various models. To see if the HDMI and all work with every model.
    Hmmm
  7. CWB32
    i have been looking at different sites for the port replicator mentioned ...
    some sites make it seem as though it will not work on anything but a '30/31 .
    however , in all cases , it looks as if the same stock photo was used and there is no picture of the back of the device and thus , no actual proof of a hdmi port being present .
    some sites list compatibility with a couple other models .
    a check at a panasonic site yielded very little information (go figure , he said sarcastically) .
    sooo ...
    there is a lack of true information (in the hand , as it were) .
    the fact of non-consistent information between sites does not prove anything , one way or the other .
    some guy could have just copied/parroted the information he found on line while doing the lay-up/write-up for their company ad .
    the fact that what appears to be a "stock photo" was used between many sites lends credence to the idea .
    at this point , what i would really trust is a service manual that lists the compatibility of various CF machines .
    man , can you imagine some poor purchasing agent buying 50 of these things and then finding out that "they don't work" ?
    my buddy had to give a police department and a sheriff's office the good news along these lines ...
    (we were set to install a bunch of docks and discovered an error ... some salesman sure lost his commission on that one)
  8. Shawn
  9. toughasnails
    My wording might not of sounded good but I really did not mean anything by it. Sorry about that.
