CF 31, MK5 gps/4g
Discussion in 'Panasonic' started by jose gomes, Aug 26, 2016.
Tags:
  1. jose gomes
    jose gomes Newbie
    Hello,
    Following your sugestions i found 2 diferent antennas inside. Both are for WWAN. Brow cable is labeled as "WWAN Aux" (DFUP2543ZA), and grey as "WWAN+LTE" (DFUP2533ZA). Should i connect the two cables to "EM7305" in "MAIN" and "AUX"?
    Witch software should i install to test the 4G, and where can i find it?
    Thanks again for you ideas and patience.
    Best regards
  2. Shawn
    WWAN+LTE" (DFUP2533ZA). grey goes to MAIN
    WWAN Aux" (DFUP2543ZA), brown goes to AUX
  3. jose gomes
    jose gomes Newbie
    Cables connected. In windows "device manager-network adapaters", shows "Sierra Wireless Mobile Broadband Network Adapter". How can i test it?
  4. Shawn
    You may need to get an account with the carrier.
    WWAN is not my area of expertise. Maybe another member has more information.
  5. CWB32
    i had a devil of a time with my WWAN card ... there is some software needed in order to see if the card is really working .
    part of the software depends on what carrier (service supplier) you want to use .
    my card was used and still had some data on it from the previous owner (account) , sooo ... it retrieved some messages .
    i was fortunate that the carrier i wanted to use was the one that was installed on my '30 .
  6. jose gomes
    jose gomes Newbie
    Hello, i really cannot find any software to test the card. Does the GPS only works if there one valid SIM card inside (and one GPS antenna is connected)?
    Thanks in advance.
  7. toughasnails
