CF-30 Touchscreen Issues
Discussion in 'Panasonic' started by pcs9518, Jul 31, 2012.
  1. pcs9518
    pcs9518 Newbie
    Hi all I have four CF-30 model numbers CF-30CAQAZBM BIOS Version 1.01L19 EC Version 1.10L10 where the touchscreens only work in Windows Vista or 7 and not XP
    Touchscreen does not show in BIOS like CF-29 units.
    Fujitsu Driver from Panasonic will not load in Windows XP but touchscreen works like a champ in Vista or 7 without any drivers. All 4 30's do the same exact thing in XP, Vista, 7 and BIOS what in the world is going on how do you make it work in XP???
    Thanks in advance :)
  2. db04p71
    db04p71 Notebook Deity
    You need to install the XP bios. The bios you have is for Vista.
    XP Downgrade bios and EC
  3. deputykester
    deputykester Newbie
    Here's a question that I have that hopefully falls inline with this thread. I have a CF-30c that used to run with XP. I recently installed Windows 7 on it and thanks to your forums here, just about have all the bugs worked out. The touchscreen still doesn't calibrate and from the reading I've done here I need to flash the BIOS so that it runs at the Vista version, 30m1bl18, and I should be good to go. I'm going to show my id10t card here because I cannot create bootable disc minus the config.sys and autoexec.bat files. If possible, can somebody point me the right direction to accomplish this part of the Panasonic's flash instructions?
  4. toughasnails
    Welcome to the toughbook forum
    ...No need to make a bootable disk. Just download the file..double click it and follow what it says.. It is very easy to update it
    I downloaded mine from the japan site
  5. circos
    circos Notebook Enthusiast
    Windows XP Tablet Edition ?
  6. toughasnails
    Nope...XP Pro is what you use for the CF-30
  7. deputykester
    deputykester Newbie
    Thanks for pointing me in that direction. It did the trick, was completely painless, AND I didn't have to build a bootable disc. The touchscreen calibrates, which was the final bug I needed to work through on these CF-30c Windows 7 upgrades. Thank you for the assistance!
  8. circos
    ...Whatever
    Once You have all upgrades there are good to know.
  9. chicoicho
    chicoicho Newbie
    Big Thanks man :thumbsup:
  10. toughasnails
    Glad we could help.
