CF-30 MK1 Memory , HDD and W7 upgrade Info
Discussion in 'Panasonic' started by SirJ, Jan 29, 2016.
  1. Shawn
    I have used a 2nd HDD in the optical drive bay. It will work and boot, BUT it must be an IDE drive.
    You remove the DVD/CD drive from it's caddy and put the HDD adapter in the DVD/CD caddy.
    I do have the IDE drive and adapter. The drive is a HDD and not a SSD.
    I doubt that an expresscard will boot, but I am not sure.
  2. Truchmann
    Truchmann Newbie
    Thank you guys for the piece of knowledge you gave to me. I' ve never taken the native HDD out of my CF-30 to see which type it is: SATA or PATA but somehow, or somebody ealier said it to me, I believe it must be a SATA HDD. So, tell me which latest BIOS to the CF-30 is and if PCI bus is used with the ExpressCard HDD or SSD then this CF-30 should boot fromit?
  3. toughasnails
    Your HDD is a SATA and my guess you have the latest bios update . There's only 2, XP bios and W7 bios (vista) update. What is your bios #.
  4. Shawn
    The main hard drive is SATA,,,BUT the optical drive is PATA/IDE. This is true on ALL CF30's.
    For a 2nd hard drive in a CF 30 optical drive bay to work properly, it must be PATA/IDE. I have already done this in the past. That's why I still have these extra parts laying around.
    I have put a 2nd hard drives in 2 different CF30's and in CF 52's mk2 thru mk4.
    Odds are the Panasonic bios is designed to not boot from an Expresscard. You would need to test it out to be sure.
    Lets do a search and see what we find...hold on
    UNCNDL1 likes this.
  5. Shawn
    reading material
    http://forum.notebookreview.com/threads/express-card-ssd-in-cf-30.770477/
    http://forum.notebookreview.com/threads/toughbook-cf-30-second-hard-drive.740459/
    http://forum.notebookreview.com/threads/cf-30-exresscard-question.383166/#post-4869647
    http://forum.notebookreview.com/threads/the-official-cf-30-thread.264961/#post-3531959
    Thank you for your reply. My BIOS currently is v1.00L14.
    toughasnails likes this.
  6. Truchmann
    Truchmann Newbie
  7. Shawn
    No---
    The hard drive MUST be native PATA/IDE in order for it to boot.
    The drive will have 44 pins on it
    The adapter looks like this. They are difficult to find since PATA/IDE drives are not used much anymore.
    I do have 1-2 of them...
  8. safn1949
    safn1949 I'm sure I'm on the wrong planet
    IDE drives new from China, I needed a new one and it did have zero hours when I tested it. I also have a maybe new one here if you want it, was a freebee.
  9. Shawn
    a frisbee....:confused::D:D:D....oh that was freebee
